Help!!!
Only older versions of php mailer works
Deprecated: __autoload() is deprecated, use spl_autoload_register() instead in /home/vol11_6/hosticy.ml/www/htdocs/libraries/PHPMailer-master/PHPMailerAutoload.php on line 45
Fatal error: Uncaught phpmailerException: SMTP connect() failed. https://github.com/PHPMailer/PHPMailer/wiki/Troubleshooting in /home/vol11_6/hosticy.ml/www/htdocs/libraries/PHPMailer-master/class.phpmailer.php:1541 Stack trace: #0 /home/vol11_6/hosticy.ml/www/htdocs/libraries/PHPMailer-master/class.phpmailer.php(1335): PHPMailer->smtpSend('Date: Tue, 18 M...', 'Hi! You request...') #1 /home/vol11_6/hosticy.ml/www/htdocs/libraries/PHPMailer-master/class.phpmailer.php(1213): PHPMailer->postSend() #2 /home/vol11_6/hosticy.ml/www/htdocs/functions.php(235): PHPMailer->send() #3 /home/vol11_6/hosticy.ml/www/htdocs/process/register.php(78): send_mail(Array) #4 {main} thrown in /home/vol11_6/hosticy.ml/www/htdocs/libraries/PHPMailer-master/class.phpmailer.php on line 1541
No one is active on the old topic.
I am using Google SMTP
I also modified the php version and the autoload error is gone but i still get this error:
Fatal error: Uncaught exception 'phpmailerException' with message 'SMTP connect() failed. https://github.com/PHPMailer/PHPMailer/wiki/Troubleshooting' in /home/vol11_6/hosticy.ml/www/htdocs/libraries/PHPMailer-master/class.phpmailer.php:1541 Stack trace: #0 /home/vol11_6/hosticy.ml/www/htdocs/libraries/PHPMailer-master/class.phpmailer.php(1335): PHPMailer->smtpSend('Date: Tue, 18 M...', 'Hi! You request...') #1 /home/vol11_6/hosticy.ml/www/htdocs/libraries/PHPMailer-master/class.phpmailer.php(1213): PHPMailer->postSend() #2 /home/vol11_6/hosticy.ml/www/htdocs/functions.php(235): PHPMailer->send() #3 /home/vol11_6/hosticy.ml/www/htdocs/process/request_activate_account.php(43): send_mail(Array) #4 {main} thrown in /home/vol11_6/hosticy.ml/www/htdocs/libraries/PHPMailer-master/class.phpmailer.php on line 1541
3 hours ago, MS-DOS said:
You are using the legacy version of PHPMailer: https://github.com/PHPMailer/PHPMailer/tree/5.2-stable which is compatible up to version 7.0 of PHP according to what is indicated on the project page https://github.com/PHPMailer/PHPMailer make sure you are at version 7.0 otherwise check that the SMTP identifier is correct.
Project Burger doesnt works without the custom autoloader
It was removed in php mailer 6.0
  • 4 months later...
This is more a place for their GitHub, but to fix that error you have to enable less secure apps in your Google account.
