On 3/20/2018 at 3:31 AM, Adil Tibari said:
hi, can anyone Help me With WMCS Or WHMC
If you are trying to host WHMCS on other server than your reseller server than it will not work.
I asked a question from other shared hosting that will i able to run WHMCS they said that WHMCS requires more resource usage so it can't be used
You can only use WHMCS for MyOwnFreeHost on your reseller server not on any other server
:D
19 hours ago, PlanetCloud said:
That is actually NOT TRUE...
Because I setted up my WHMCS at another server other than BYET for testing purposes.
You CAN use it on other server.
Depending on the hosting plan/package, some shared hosting might reject it but I think WHMCS require less juice than WordPress (ref : http://www.wpbeginner.com/wp-tutorials/how-wordpress-actually-works-behind-the-scenes-infographic/)
I had contacted with the hosting provider on which i am running one of my wordpress website. They have good servers but they said that WHMCS use more resources, so i can't use it on other shared hosting
WordPress looks complicated when explained like that, but almost every CMS and application is just as complex. And I can guarantee you: WHMCS uses far more resources than WordPress.
can anyone help me with the orderbox template seetings, its not working, I coudnt find comparission template ? i only find
  Name Size Last Modified (India Standard Time) Type Perms
boxes
4 KB
Jan 6, 2018 8:16 AM
httpd/unix-directory
0755
cloud_slider
4 KB
Jan 6, 2018 8:16 AM
0755
cpanelapi
4 KB
Today 3:25 PM
0755
modern
4 KB
Jan 6, 2018 8:16 AM
0755
premium_comparison
4 KB
Jan 6, 2018 8:16 AM
0755
pure_comparison
4 KB
Jan 6, 2018 8:16 AM
0755
standard_cart
4 KB
Jan 6, 2018 8:16 AM
0755
supreme_comparison
4 KB
Jan 6, 2018 8:16 AM
0755
universal_slider
4 KB
Jan 6, 2018 8:16 AM
0755
cpanelapi.zip
69.5 KB
Today 3:20 PM
package/x-generic
0644
index.php
i have already uploaded cpanelapi, and it works on comparison template. and i also not fine that code in all these orderforms to edit it.I am using whmcs 742. please help.
While order its showing blank screen. you can check it at http://cotlasweb.in/whmcs/cart.php?a=add&pid=1
Also I have tried to order using default template and setting i have my own domain I ordered sucessfully but while at admin panel i was activating order status from pending to activate. its not creating id. throwing this error.
cPanel API Unreachable: <!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN"> <html><head> <title>404 Not Found</title> </head><body> <h1>Not Found</h1> <p>The requested URL /json-api/create_user_session.php was not found on this server.</p> </body></html>
Hmmm, i received that answer again that whmcs uses more resources so it can't be used on shared hosting from my host
May be you are right.
You seem to be using a nulled copy of whmcs, this is against the rules. Please use a legit license.
41 minutes ago, cotlasweb said:
Is it really a whmcs problem ? because i have accessed the api url directly via browser but its showing the same error.
you can see that...here https://panel.myownfreehost.net:2087/json-api/create_user_session.php
it says url not found
Not Found
The create_user_session method of the WHM API is not supported on MyOwnFreeHost, so the "Login to cPanel" button won't work in WHMCS.
I had never received this error. I got only array () error and i had solved it.
The Requested URL /json-api/create_user_session.php only come when you try to login to whm from whmcs admin panel. It doesn't seems to come while activating Orders.
Do you entered IP Address of your server in myownfreehost allowed IP Addresses?
Are you using .tk domain for providing sub-domain? Or Are you using API of .tk domain? If yes then try to use API of .ml domain and use .ml domain as subdomain then your problem will be solved
  • 2 years later...
I've been getting the Array Error too do you know how you managed to solve it?
This topic is now closed to further replies.
