Can I create my own Login and Sign Ups for my users?
ExploreWeb
Hi @ExploreWeb
Yes! You can create custom login and signup pages.
You may edit the default pages as per your wish.
Or you can create a custom clientarea like infinityfree or profreehost by which you can gain complete control over your design. ?
Edited by uHost
you can create your own sign up page with html & css and php and in the form add
<form method=post action="https://order.<?php echo $yourdomain?>/register2.php">
and for captcha use this link https://ifastnet.com/image.php (because https is enabled on this domain and also because order.yourdomain.tld [whatever your domain is] does not have a ssl certificate )
example
<td style="text-align: left;" colspan="21">
<font size="-1"><span style="font-family: Helvetica,Arial,sans-serif;">
<table>
<tr><th style="text-align: left;">Username<td><input type=text name=username size=30 value="" maxlength="16" onkeyup="return ismaxlength(this)">
<tr><th>&nbsp;<td>&nbsp;
<tr><th style="text-align: left;">Password<td><input type=password name=password size=30 maxlength="25" onkeyup="return ismaxlength(this)">
<tr><th style="text-align: left;">Email Address<td><input type=text name=email size=30 value="">
<tr><th style="text-align: left;"><td>
<tr><th>&nbsp;<td>
<tr><th style="text-align: left;">Site Category<td><select size="1" name="website_category">
<option>Personal</option>
<option>Business</option>
<option>Hobby</option>
<option>Forum</option>
</select>
</td>
<tr><th>&nbsp;<td>
<tr><th style="text-align: left;">Site Language<td>
<select size="1" name="website_language">
<option>English</option>
<option>Non-English</option>
</select>
</td>
<input type=hidden name=id value="<?PHP echo $id; ?>">
<tr><th style="text-align: left;">Security Code<td><img src="nk https://ifastnet.com/image.php?id=<?PHP echo $id; ?>">
<tr><th style="text-align: left;">Enter Security Code<td><input type=text name=number size=30>
<tr><th colspan=2><input type=submit value="Register" name=submit>
</table>
</form>
Edited by Nabeel
