Advanced login customization
7 hours ago, Elijah Porter said:
I would like it if you could change text color on the login page. And also change the border colors. Note: I do not necessarily mean editing the whole page, I just mean adding more inputs like text color and border color. Is this possible?
You can create your own login page. There is a few lines of code that are provided inside a tab in the reseller panel that are used for login, copy that, and integrate it with your design.
