Guest paulyii Posted March 28, 2014 Share Posted March 28, 2014 (edited) I had used the Script Installer to install "b2evolution" after the completion . [COLOR=#0000FF][B]"Install Completed"[/B][/COLOR] when i tried to load my site ( [B][URL]https://paulyii.byethost24.com/blog/[/URL][/B][URL="https://paulyii.byethost24.com"] )[/URL] Just a[COLOR=#FF0000][B] BLANK[/B][/COLOR] page appeared ( NOTHING at all ) What happened ? what did i missed out anything ? Please helps. Thanks and Regards always !! Edited March 28, 2014 by paulyii Quote Link to comment Share on other sites More sharing options...
Guest paulyii Posted March 31, 2014 Share Posted March 31, 2014 I tested it under the "text" directory .. the page appears siad : " [quote][b]Test successful. If this page can be loaded, it means that the .htaccess that is being staged in this test folder did *NOT* crash apache. This is good. This means we can use that .htaccess file in production.[/b][/quote] now... where did i did wrong ? i had all the necessary files [b]chmod[/b] as required. [B]can anyone advise me ?[/B] ( [COLOR=#FF0000][B]NB: i cant submit any ticket to seek help too[/B][/COLOR] ) Quote Link to comment Share on other sites More sharing options...
Guest BurkeKnight Posted April 8, 2014 Share Posted April 8, 2014 Please use the ticket system in your control panel to get support, if that is not working, you can file a support ticket via: [url]https://byet.org/premiumsupport[/url] Quote Link to comment Share on other sites More sharing options...
Guest hostdude Posted July 13, 2014 Share Posted July 13, 2014 Could be an error in the .htaccess file. Quote Link to comment Share on other sites More sharing options...
Guest hostddl Posted November 19, 2014 Share Posted November 19, 2014 try to install b2evolution manually Quote Link to comment Share on other sites More sharing options...
