Hostrr Posted July 23, 2017 Share Posted July 23, 2017 I did see the InfinityFree and Ninth sites with custom sign up page, but the question is... HOW? I was looking the template provided by MOFH and there's a POST form with "order.yourhost.com/register2.php", so if exists a subdomain and we can't change inside it... How to custom the sign up? Thank you. Quote Link to comment Share on other sites More sharing options...
BSthuliwal Posted July 24, 2017 Share Posted July 24, 2017 Its not custom sign up. They had created a custom client management portal based on the whm api. You can use whmcs instead if you can create a custom one. You can get example at geekbiz.tk Quote Link to comment Share on other sites More sharing options...
mike Posted July 24, 2017 Share Posted July 24, 2017 20 hours ago, Hostrr said: I did see the InfinityFree and Ninth sites with custom sign up page, but the question is... HOW? I was looking the template provided by MOFH and there's a POST form with "order.yourhost.com/register2.php", so if exists a subdomain and we can't change inside it... How to custom the sign up? Thank you. To do this you need to create a plugin to implement it with you html/php, or billing system. There are various resources available in the forum. https://www.byet.net/index.php?/topic/1927-myownfreehost-api-client/#comment-2946 Quote Link to comment Share on other sites More sharing options...
BSthuliwal Posted July 25, 2017 Share Posted July 25, 2017 Or if you can code a bit then try editing the existing version of cpanel module of whmcs. For inspiration check at geekbiz.tk. Quote Link to comment Share on other sites More sharing options...
selamhosting Posted September 18, 2017 Share Posted September 18, 2017 On 24.07.2017 at 5:13 PM, mike said: To do this you need to create a plugin to implement it with you html/php, or billing system. There are various resources available in the forum. https://www.byet.net/index.php?/topic/1927-myownfreehost-api-client/#comment-2946 I use whmcs if you ask me if you help me I have not done it in 1 week please nobody helps Quote Link to comment Share on other sites More sharing options...
mike Posted September 19, 2017 Share Posted September 19, 2017 11 hours ago, selamhosting said: I use whmcs if you ask me if you help me I have not done it in 1 week please nobody helps If you use whmcs its a piece of cake to implement. And is "officially " supported, you can find how to configure it on MOFH site. Quote Link to comment Share on other sites More sharing options...
selamhosting Posted September 20, 2017 Share Posted September 20, 2017 17 hours ago, mike said: If you use whmcs its a piece of cake to implement. And is "officially " supported, you can find how to configure it on MOFH site. I can not make a cause but on the support nobody wants to help nobody hiding secrets nobody wants to give nobody thank you Quote Link to comment Share on other sites More sharing options...
mike Posted September 20, 2017 Share Posted September 20, 2017 4 hours ago, selamhosting said: I can not make a cause but on the support nobody wants to help nobody hiding secrets nobody wants to give nobody thank you Im not very sure of what you are trying to say, but if you use whmcs there are no secrets. You can even find a guide in MOFH page. But if you are talking about the custom API client, well, who would want to give to anyone the only thing that makes them different. Quote Link to comment Share on other sites More sharing options...
