New site in Byet - however FTP (FileZilla, Core FTP, SmartFTP) does not connect!
atlascana
Hello!
I'm new here!
I'm testing BYET! And I'm pretty satisfied compared to the other free hosts!
But I am having two problems, they are:
1) I can not connect via FTP in any way, but the site file manager works! Does anyone know how to solve it?
2) The file size to be sent by an FTP client is larger than the site allows? I have a several GEOJASON files that have 11Mb and the maximum of the site is 9.48Mb! Any idea ?
Thank you all!
43 minutes ago, atlascana said:
Hello!
I'm new here!
Thank you all!
Check if the ftp server you are trying to connect to is the one you should be connecting to. The username and passwords are the same as the Vpanel ones.
Usually the ftp server is " ftp.the subdomain you registered with "
If you still can't connect after checking all credentials are correct, contact support at https://support.ifastnet.com
Hi Mike!
Thanks for that quick reply!
I did these host / password checks and tested other platforms before posting here, but it did nothing! :(
So, I noticed in the forum another user that had the same problem, and that I did! (https://www.byet.net/index.php?/topic/2033-ftp-server-down/)
But the support replied that they were migrating the free servers, and that could cause some problem!
Put that in a month ago!
Can I register on this site that you indicated even though I am not a PREMIUM user?
28 minutes ago, atlascana said:
Hi Mike!
Yes you can.
This topic is now closed to further replies.
