Audiomonk Posted September 20, 2017 Share Posted September 20, 2017 Hi, Firstly I tried to add a support ticket, but the links are broken? Many of the links here I click on it says not found. Anyway, I'm trying to whitelist IP addresses for a wordpress plugin which optimises images to take less space. I've been given a range of IP addresses, how do I whitelist them? Or do you do it ? Link to comment Share on other sites More sharing options...
mike Posted September 20, 2017 Share Posted September 20, 2017 50 minutes ago, Audiomonk said: Hi, Firstly I tried to add a support ticket, but the links are broken? Many of the links here I click on it says not found. Anyway, I'm trying to whitelist IP addresses for a wordpress plugin which optimises images to take less space. I've been given a range of IP addresses, how do I whitelist them? Or do you do it ? As far as I'm aware, there are no tools on Vpanel to whitelist IPs. This link might help you, but I'm not sure it will fit your needs, as I haven't test it out myself. Link to comment Share on other sites More sharing options...
Audiomonk Posted September 21, 2017 Author Share Posted September 21, 2017 Thanks for the response, I tried whitelisting IP's from .htaccess but it causes my site to fall over. Not sure what to do now, maybe there's a wordpress plugin that might do it, but if the Host have blocked certain IP addresses, I won't be able to get past that without them. Link to comment Share on other sites More sharing options...
