Dhananjay Posted June 7, 2018 Share Posted June 7, 2018 Dear, Please tell me what is WHM API in my Reseller hosting Panel and how can I use it? Quote Link to comment Share on other sites More sharing options...
mike Posted June 7, 2018 Share Posted June 7, 2018 2 hours ago, Dhananjay said: Dear, Please tell me what is WHM API in my Reseller hosting Panel and how can I use it? The WHM API*, is a API used to communicate with the MyOwnFreeHost (MOFH) system, and it allows you to create, and suspend accounts among other features. It makes also possible the communication to the system if you choose to host your site outside of BYET/IFASTNET. *It is also used for other systems than MOFH, but in this case it's been used for MOFH. Quote Link to comment Share on other sites More sharing options...
Anyx Posted June 7, 2018 Share Posted June 7, 2018 2 hours ago, mike said: The WHM API*, is a API used to communicate with the MyOwnFreeHost (MOFH) system, and it allows you to create, and suspend accounts among other features. It makes also possible the communication to the system if you choose to host your site outside of BYET/IFASTNET. *It is also used for other systems than MOFH, but in this case it's been used for MOFH. Is it only for use withing WHMCS or it can be used on simple PHP also? Quote Link to comment Share on other sites More sharing options...
AA22Dev Posted June 7, 2018 Share Posted June 7, 2018 2 hours ago, PCTipsGR said: Is it only for use withing WHMCS or it can be used on simple PHP also? With that API you can create your own Client area It can be used in PHP Quote Link to comment Share on other sites More sharing options...
Ramboj686 Posted June 7, 2018 Share Posted June 7, 2018 7 hours ago, PCTipsGR said: Is it only for use withing WHMCS or it can be used on simple PHP also? No..You can design your own Client Area using php... For reference have a look at https://infinityfree.net Quote Link to comment Share on other sites More sharing options...
Anyx Posted June 8, 2018 Share Posted June 8, 2018 12 hours ago, Ramboj686 said: No..You can design your own Client Area using php... For reference have a look at https://infinityfree.net I know about InfinityFree, after all that is how I learnt about iFastnet/Byet/MOFH. But I am not experienced in creating my own client areas and having a autologin button. Quote Link to comment Share on other sites More sharing options...
Ramboj686 Posted June 8, 2018 Share Posted June 8, 2018 6 hours ago, PCTipsGR said: I know about InfinityFree, after all that is how I learnt about iFastnet/Byet/MOFH. But I am not experienced in creating my own client areas and having a autologin button. To develop you your own client are you should have some experience in php and for using MOFH API you should have experience in Object Oriented php as stated by Hans... Quote Link to comment Share on other sites More sharing options...
