WHMCS Integration
Mauwiks
Hi Guys,
I'm confused what domain should I use here whether the WHMCS domain or my MOFH reseller domain:fZ7YUaP.png
Please enlighten me.
By the way, how do we disable the integration? When I integrated my reseller domain to use the WHM API for WHMCS, it crashed. Now I could never get it to work. Could you try reaching out for it?
Please let me know if you have any idea about this issue... Thanks further!
Edited by Mauwiks
9 hours ago, Mauwiks said:
Hi Guys,
By the way, how do we disable the integration? My reseller domain is kindtechgroup.com and when I integrated it to use the WHM API for WHMCS, it crashed. Now I could never get it to work. Could you try reaching out kindtechgroup.com?
The "API Callback URL"  is the adress MOFH servers will send for example a account status update, from active to suspended ( and other stuff ). You should use the address where you have your WHMCS installed.
And yes, your site is down.
