c64persian Posted August 1, 2024 Share Posted August 1, 2024 Hello phpbb3.3.12 when i click on mcp/moderation queue/ show this error message: SQL ERROR [ mysqli ] The SELECT would examine more than MAX_JOIN_SIZE rows; check your WHERE and use SET SQL_BIG_SELECTS=1 or SET MAX_JOIN_SIZE=# if the SELECT is okay [1104] This is caused by MAX_JOIN_SIZE set to small on the database server. how to change it? Quote Link to comment Share on other sites More sharing options...
BastelPichi Posted August 3, 2024 Share Posted August 3, 2024 Contact support at https://support.ifastnet.com Quote Link to comment Share on other sites More sharing options...
