Guest cmos Posted June 5, 2015 Share Posted June 5, 2015 Hi, I'm trying to customize the most of my web reseller (hosting-toro.com) I would like to create different pages of signup (signup.php) depending on the script that users want to install and based on data from the web where mofh provide the code for it, my idea is to create different landing pages for some scripts like wordpress and from that same landing page the user can register while installing wordpress on your hosting, the problem is that it only works when registration occurs from the signup.php file in htdocs, if rename the file to wp-signup.php not work, if I create a folder called "wp" and there keep a copy of the files geturl.php and signup.php not work either. is there any way around this? thanks and regards Quote Link to comment Share on other sites More sharing options...
BSthuliwal Posted August 5, 2017 Share Posted August 5, 2017 On 6/5/2015 at 7:52 PM, Guest cmos said: Hi, I'm trying to customize the most of my web reseller (hosting-toro.com) I would like to create different pages of signup (signup.php) depending on the script that users want to install and based on data from the web where mofh provide the code for it, my idea is to create different landing pages for some scripts like wordpress and from that same landing page the user can register while installing wordpress on your hosting, the problem is that it only works when registration occurs from the signup.php file in htdocs, if rename the file to wp-signup.php not work, if I create a folder called "wp" and there keep a copy of the files geturl.php and signup.php not work either. is there any way around this? thanks and regards no you can't create a custom sign up page as mofh doesn't support it. Quote Link to comment Share on other sites More sharing options...
Admin Posted August 6, 2017 Share Posted August 6, 2017 You could have a custom signup script if you use the API, however this is not something we support, you need to code and develop your own systems around the api . Quote Link to comment Share on other sites More sharing options...
