Domain Help
Saber
4 hours ago, Saber said:
Hi,
I need some help with my site. I have a Wordpress.org site (https://sabertooth.byethost7.com/wp/) that is hosted using byethost
I have recently purchased a domain through iFastNet.
How do I utilize the domain for my already existing Wordpress.org site?
Thanks,
Open the domain panel and search for something named " Name server " or " NS ". In the text box that shoud be next to it, you have to put ns1.byet.org, in the next " NS " put ns2.byet.org, and so on until you fill all the "NS" boxes up to ns5.byet.org. ( name server may variate, if you are not sure you can find the correct one in the addon domains tab ).
Then, in the Vpanel search for " addon domains ", and in the text box writte your domain name, and click " add domain ".
5
Thanks. I have now done this.
Is it possible to change the URL of my website to that domain name?
Currently, it is https://sabertooth.byethost7.com/wp/ but I would like it to be https://www.sabertooth-systems.com/. Is that possible?
If you point the name servers on the domain panel to the ones in wich " sabertooth.byet.... " is hosted on, you can do that.
This topic is now closed to further replies.
