Give me a template like "infinityfree.net"
Danhit
  • 4 weeks later...
  • 1 month later...
@InfinityFree is right on this one. If you want the HTML and CSS of the website, and not the actual thing, it's called Satria, but it doesn't come free, it's pretty much $9 from ThemeForest, but if you are willing to be able to invest money into your hosting business, then why not?
Where can i get a theme template that works out of the box. i'm a bit confused that nothing seems to work iwas under the impression this was an affiliate program/setup but seems i was wrong
1st problem could not get lets encrypt to work verification. (fixed after sleepless night)
2nd problem. registration does not work :(
is there a step by step setting up guide i,ve missed..please direct me
kind reguards
chris
  • 3 weeks later...
On 1/9/2018 at 10:19 AM, PlanetCloud said:
The templete for the client area is actually a ver popular template called Material Design (getmdl.io).
But it will nit be easy to just copy and paste from InfinityFree.
It does not work that way!
It will take a lot of time and efforts to make it work.
Me and Hostingaj ate trying to make something similar but we kinda discarded our plan to release it to the community because of spam we're getting but we almost finished the design and basic and Integrating the API is what left to do.
No mean to be rude or anything, just asking: by not releasing it to the community, do you mean it costs money now or anyone that doesn't spam and sends you an e-mail or something can get it?
7 hours ago, PlanetCloud said:
Demek istediğim şu:
  1. Topluluğa bırakmayacağım, çünkü para harcamakla kalmıyor, aynı zamanda zaman kazanıyordu.
    Bırakabilirim ama küçük bir ücret karşılığında
  2. Spam gönderenler için bunu almazlar.
    Katkıda bulunan ve Geliştiriciler için bunu alacaksınız.
    Ücretsiz olarak, ancak satma ya da başkasına göndermesine izin verilmiyor.
Demoyu (Sürüm 1.2) buradan bulabilirsiniz:  https://planet-api.tariktunaikartukredit.cf/
Giriş bilgileri:
Kullanıcı adı: Test25565
Şifre: 123456
Başarıyla giriş yaptıktan sonra şunu kontrol edin:  Dinamik hesap kontrolü için https://planet-api.tariktunaikartukredit.cf/ test-index.php
I want buy .
12 hours ago, PlanetCloud said:
What I meant is that :
  1. I will not release it to the community because it not only cost money but it cost time.
    I might release it but for small fee
  2. For spammers, they will not get it.
    For contributors and Developers will get it.
    For free, but they are not allowed to resell or send it to anyone else.
You can find the demo (Version 1.2) here : https://planet-api.tariktunaikartukredit.cf/
Login info :
Username : Test25565
Password : 123456
After successfully logged in, check this : https://planet-api.tariktunaikartukredit.cf/test-index.php for a dynamic account checking
Alright, then. I'm guessing it will be around $20 or so? I was thinking about buying it when it's finished and re-designing it to fit the design of my website.
1 minute ago, PlanetCloud said:
He did this to me and
@Hostingajbefore...
Sorry for bad formatting, this phone has a different stock keyboard
For the price we still have no idea but my plan is to make it like a licensing system with some files hosted on a super fast server but will only be able to get or request the file from specific domain and it will be untransferable or copyable
Ahh, okay.
Login info :
Password : 123456
About the client area, I could probably help with the front-end, though not the back-end as I don't really know much about making backends other than a simple login system.
5 minutes ago, PlanetCloud said:
Same here, I had finished the front-end but Im new to php.. Just touched php for the first time on 23 December 2017 so now all I need is to get the API working
Yeah, I'm new to PHP too, the best thing I know about back-ends is how to read the API responses and I can understand them, I just don't know how to POST and GET requests to them
