AHost Posted February 20, 2018 Share Posted February 20, 2018 i need help integrateing with whmcs please help i dont know where i would to thanks Quote Link to comment Share on other sites More sharing options...
AHost Posted February 20, 2018 Author Share Posted February 20, 2018 Hi Yes i get a error when i try i got the hook in but it says a error saying the api user name and password are incorrect Quote Link to comment Share on other sites More sharing options...
AHost Posted February 20, 2018 Author Share Posted February 20, 2018 here my error Module Create Failed - Service ID: 6 - Error: The API username you are using appears to be invalid 1. 24The API username you are using appears to be invalid 2. The API key you are using appears to be invalid 1. . Quote Link to comment Share on other sites More sharing options...
AHost Posted February 20, 2018 Author Share Posted February 20, 2018 1 hour ago, PlanetCloud said: Hi, There's a documentation for it. https://myownfreehost.net/cpanel-api.php Yeah i try that but dont understand do i install cpanel api or mofh api Quote Link to comment Share on other sites More sharing options...
AHost Posted February 20, 2018 Author Share Posted February 20, 2018 7 hours ago, PlanetCloud said: Hi, This is a pretty straight-forward error. Your API Username and Password is Incorrect! Go to Reseller Panel > API > Setup WHM API > Copy the Username and Password I did that like 15times same error i will upload it and send you pic of my api username and password hook_subwhois.php Quote Link to comment Share on other sites More sharing options...
