Ramboj686 Posted April 11, 2018 Author Share Posted April 11, 2018 6 minutes ago, InfinityFree said: Just set it up like you would set up any other hosting service? But I can recommend setting up one domain for your main website (infinityfree.net in my case) and another domain for customers (epizy.com primarily, for me). Doing so gives you a lot more flexibility in hosting your own site and helps ensure that a phishing site slipping the net won't trash the reputation of your main site. Ohh...Actually I was gonna do something like that (Still planning) at first but i was thinking of only signing up on the other site ..f#@k brilliant man Quote Link to comment Share on other sites More sharing options...
Ramboj686 Posted April 11, 2018 Author Share Posted April 11, 2018 @InfinityFree you're just using epizy for usernames ...Nice buddy Quote Link to comment Share on other sites More sharing options...
AA22Dev Posted April 11, 2018 Share Posted April 11, 2018 11 hours ago, InfinityFree said: If Cloudflare breaks your site, then it's your website which is not working as it should. Many, many people use Cloudflare on free hosting without any problems. But it's important to note that infinityfree.net itself is not actually hosted on free hosting. It's one of the biggest free hosting brands in the world, you can't host a website that popular on a free hosting account. I think @PlanetCloud is talking about a website for MyOwnFreeHost. My suggestion is to use cloudflare from within cPanel of you MyOwnFreeHost account other free website (not reseller websites using default theem) can use cloudflare without getting broken Quote Link to comment Share on other sites More sharing options...
Ramboj686 Posted April 12, 2018 Author Share Posted April 12, 2018 7 hours ago, Aqib said: I think @PlanetCloud is talking about a website for MyOwnFreeHost. My suggestion is to use cloudflare from within cPanel of you MyOwnFreeHost account other free website (not reseller websites using default theem) can use cloudflare without getting broken I'll look into this...... Quote Link to comment Share on other sites More sharing options...
AA22Dev Posted April 12, 2018 Share Posted April 12, 2018 17 hours ago, PlanetCloud said: Cloudflare SSL works fine but what I meant by "breaking" the site is that upon creating a subdomain whether it's from cpanel or thru signup forms, we had to manually add an A record to Cloudflare for it to solve the DNS. If this is not done, then the new subdomain (even after 3 days) will still shows up as DNS_NOT_FOUND. Cloudflare actually has an API for this sort of thing but here's the problem : You only know the subdomain but you did not know the server IP the domain is hosted. IP can change from time to time The IP is not the same for all accounts even if it is your subdomain So with this, I do not recomend Cloudflare for Reseller account, but I do recomend it for non-reseller account/sites. If you attach your website via cPanel to cloudflare than you don't need to take care for A records. It will not cause any problem Quote Link to comment Share on other sites More sharing options...
Ramboj686 Posted April 13, 2018 Author Share Posted April 13, 2018 11 hours ago, Aqib said: If you attach your website via cPanel to cloudflare than you don't need to take care for A records. It will not cause any problem I tried this it worked but not for Sub-Domains and also the SSL is activated but CloudFlare is not showing status of the SSL. Quote Link to comment Share on other sites More sharing options...
AA22Dev Posted April 13, 2018 Share Posted April 13, 2018 11 hours ago, PlanetCloud said: Hmmm, I'll try this method later... ok 5 hours ago, Ramboj686 said: I tried this it worked but not for Sub-Domains and also the SSL is activated but CloudFlare is not showing status of the SSL. Cloudflare activate SSL on your website. I had tried and it worked and doesn't cause any problem on my website Quote Link to comment Share on other sites More sharing options...
Ramboj686 Posted April 14, 2018 Author Share Posted April 14, 2018 16 hours ago, PlanetCloud said: The site is secured with SSL https://rehostind.com But I dont know if this works for subdomain or not It is secured but not working for Sub-Domains except cpanel.rehostind.com....Currently I've opted for Premium Trial so can't experiment on site... Quote Link to comment Share on other sites More sharing options...
AA22Dev Posted April 14, 2018 Share Posted April 14, 2018 1 hour ago, PlanetCloud said: I think the subdomain owner (Client) has to do this on their own. Im not sure about this tho but to my knowledge, thats how it works Sub-domain can not be attached to cloud flare. Only addon domains can be attached Quote Link to comment Share on other sites More sharing options...
Ramboj686 Posted April 15, 2018 Author Share Posted April 15, 2018 19 hours ago, Aqib said: Sub-domain can not be attached to cloud flare. Only addon domains can be attached What if we create a page rule with *.Example.com for "Always HTTPS"? Quote Link to comment Share on other sites More sharing options...
Ramboj686 Posted April 15, 2018 Author Share Posted April 15, 2018 1 minute ago, PlanetCloud said: If a certificate was in place for the *, then go ahead! I didn't quite get that.. Quote Link to comment Share on other sites More sharing options...
AA22Dev Posted April 15, 2018 Share Posted April 15, 2018 7 hours ago, Ramboj686 said: What if we create a page rule with *.Example.com for "Always HTTPS"? No, that will also not work for sub domains Quote Link to comment Share on other sites More sharing options...
