GRAV - Softaculous - 404 Error - Info: Grav appears to not be compatible
bentxt
Hello User,
how can i solve the  404 Error problem?
If i install Wordpress i doesn't have this problem
https://learn.getgrav.org/17/troubleshooting/page-not-found
https://learn.getgrav.org/17/basics/requirements
  1. Web Server (Apache, Nginx, LiteSpeed, Lightly, IIS, etc.)
  2. PHP 7.3.6 or higher
  3. hmm... that's it really, (but please look at PHP requirements for a smooth experience)!
I'm use PHP Version 7.4.8.
https://www.softaculous.com/
This the troubleshooting guide, " i" don't can solve the problem.
I can log in as System Administrator.
Thank you
betxt
Edited by bentxt
  • bentxt changed the title to GRAV - Softaculous - Softaculous - GRAV
https://learn.getgrav.org/17/troubleshooting/page-not-found#htaccess-test-script
Grav Apache .htaccess Tester
hp_value display_errors On
php_value mbstring.http_input auto
php_value date.timezone Europe/Berlin
<IfModule mod_rewrite.c>
RewriteEngine On
## Begin RewriteBase
# If you are getting 500 or 404 errors on subpages, you may have to uncomment the RewriteBase entry
# You should change the '/' to your appropriate subfolder. For example if you have
# your Grav install at the root of your site '/' should work, else it might be something
# along the lines of: RewriteBase /<your_sub_folder>
# RewriteBase /
## End - RewriteBase
## Begin - X-Forwarded-Proto
# In some hosted or load balanced environments, SSL negotiation happens upstream.
# In order for Grav to recognize the connection as secure, you need to uncomment
# the following lines.
# RewriteCond %{HTTP:X-Forwarded-Proto} https
# RewriteRule .* - [E=HTTPS:on]
## End - X-Forwarded-Proto
## Begin - Exploits
# If you experience problems on your site block out the operations listed below
# This attempts to block the most common type of exploit `attempts` to Grav
# Block out any script trying to use twig tags in URL.
RewriteCond %{REQUEST_URI} ({{|}}|{%|%}) [OR]
RewriteCond %{QUERY_STRING} ({{|}}|{%25|%25}) [OR]
# Block out any script trying to base64_encode data within the URL.
RewriteCond %{QUERY_STRING} base64_encode[^(]*\([^)]*\) [OR]
# Block out any script that includes a <script> tag in URL.
RewriteCond %{QUERY_STRING} (<|%3C)([^s]*s)+cript.*(>|%3E) [NC,OR]
# Block out any script trying to set a PHP GLOBALS variable via URL.
RewriteCond %{QUERY_STRING} GLOBALS(=|\[|\%[0-9A-Z]{0,2}) [OR]
# Block out any script trying to modify a _REQUEST variable via URL.
RewriteCond %{QUERY_STRING} _REQUEST(=|\[|\%[0-9A-Z]{0,2})
# Return 403 Forbidden header and show the content of the root homepage
RewriteRule .* index.php [F]
## End - Exploits
## Begin - Index
# If the requested path and file is not /index.php and the request
# has not already been internally rewritten to the index.php script
RewriteCond %{REQUEST_URI} !^/index\.php
# and the requested path and file doesn't directly match a physical file
RewriteCond %{REQUEST_FILENAME} !-f
# and the requested path and file doesn't directly match a physical folder
RewriteCond %{REQUEST_FILENAME} !-d
# internally rewrite the request to the index.php script
RewriteRule .* index.php [L]
## End - Index
## Begin - Security
# Block all direct access for these folders
RewriteRule ^(\.git|cache|bin|logs|backup|webserver-configs|tests)/(.*) error [F]
# Block access to specific file types for these system folders
RewriteRule ^(system|vendor)/(.*)\.(txt|xml|md|html|json|yaml|yml|php|pl|py|cgi|twig|sh|bat)$ error [F]
# Block access to specific file types for these user folders
RewriteRule ^(user)/(.*)\.(txt|md|json|yaml|yml|php|pl|py|cgi|twig|sh|bat)$ error [F]
# Block all direct access to .md files:
RewriteRule \.md$ error [F]
# Block all direct access to files and folders beginning with a dot
RewriteRule (^|/)\.(?!well-known) - [F]
# Block access to specific files in the root folder
RewriteRule ^(LICENSE\.txt|composer\.lock|composer\.json|\.htaccess)$ error [F]
## End - Security
</IfModule>
# Begin - Prevent Browsing and Set Default Resources
Options -Indexes
DirectoryIndex index.php index.html index.htm
# End - Prevent Browsing and Set Default Resources
</div>
How can i solved the probem?
Edited by bentxt
  • bentxt changed the title to GRAV - Softaculous - 404 Error
This is my grav Testsite, installed with Softaculous.
https://bastelben.22web.org/
https://www.w3.org/
https://validator.w3.org/
https://validator.w3.org/nu/?doc=http%3A%2F%2Fbastelben.22web.org%2F
bentxt with WordPress, Softaculus
https://bastelbenwp.22web.org/
https://validator.w3.org/nu/?doc=http%3A%2F%2Fbastelbenwp.22web.org%2F
bentxt try to install Shopware
  The following errors were found
  The following errors were found :
    Could not make the query numbered : 174
    MySQL Error No : 1064
    MySQL Error : You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'GENERATED ALWAYS AS (json_unquote(json_extract(`price`,'$.taxStatus'))) VIRTU...' at line 22
bentxt Joomla - ok
https://bastelbentest.22web.org/
Edited by bentxt
i don't find the solution for me. ?
PHP Info
phpinfo.php
PHP Version 7.4.8
System Linux freeweb12-2.byetcluster.com 2.6.32-896.16.1.lve1.4.54.el6.x86_64 #1 SMP Wed May 2 07:43:19 EDT 2018 x86_64
Server API Apache 2.0 Handler
Configuration File (php.ini) Path /etc/php70
Loaded Configuration File /etc/php70/php.ini
Scan this dir for additional .ini files (none)
Additional .ini files parsed (none)
Zend Extension Build API320190902,NTS
PHP Extension Build API20190902,NTS
Zend Signal Handling enabled
Zend Memory Manager enabled
Zend Multibyte Support provided by mbstring
IPv6 Support disabled
DTrace Support disabled
Registered PHP Streams https, ftps, compress.zlib, php, file, glob, data, http, ftp, phar, zip
Registered Stream Socket Transports tcp, unix, udg, ssl, tls, tlsv1.0, tlsv1.1, tlsv1.2, tlsv1.3
Registered Stream Filters zlib.*, convert.iconv.*, string.rot13, string.toupper, string.tolower, string.strip_tags, convert.*, consumed, dechunk
Edited by bentxt
https://bastelben.22web.org/htaccess_tester.php
The file .htaccess exists and is readable to the webserver. The file contains:
RewriteEngine On
# RewriteBase /
## Begin - Exploits
## End - Exploits
## Begin - Index
## End - Index
## Begin - Security
## End - Security
</IfModule>
Options -Indexes
</div>
.htaccess
RewriteEngine On
# RewriteBase /
## Begin - Exploits
## End - Exploits
## Begin - Index
## End - Index
## Begin - Security
## End - Security
</IfModule>
Support byet.net:
Hi there,
Grav appears to not be compatible / supported by free hosting and has now been removed from Softaculious.
Thank you and stay safe !
Please let us know if there is anything we can do.
Best Regards
iFastNet Premium hosting provides Unlimited disk space & daily hits, free domains, VERY powerful faster servers and 100's more benefits!
To upgrade this account to *Awesome* Premium Hosting - follow these simple steps :
1) Click upgrade plan link/icon in your free hosting cPanel or visit https://ifastnet.com
2) Choose your premium plan and make payment.
3) Reply here with your order or invoice number and we will upgrade your entire free hosting account files/domains to Premium!
iFastNet - Proud winners of the TMT Telecom 2017 "Best Premium Hosting" award.
Premium hosting solutions available from https://ifastnet.com solid secure fast hosting !
Edited by bentxt
  • bentxt changed the title to GRAV - Softaculous - 404 Error - Info: Grav appears to not be compatible
