MILD API:Client - A simpler API for resellers [PROJECT MILD]
PlanetCloud
Hello Everyone,
MILD API was an API that can be used easily with PHP, JS or any other langugage that supports HTTP requests.
We had Public/Open API and Private API.
The Public/Open API (will be mentioned ad Public) can be used without any authentication such as username/password.
This was used on Project Logged version 1.7 and above for the domain verification. Which you can check it out here :
Quick Preview :
There are more feature's coming to Public API soon.
The Private API on the other hand requires Authentication and depending for it's use, it might require MOFH API Key and Password and a given IP to be whitelisted.
The Private API can Create Accounts without API KEY and PASSWORD or whitelisting any server IP.
More feature's are also coming to the Private API and we can't wait to see what you can built.
You can check out the respository here : https://github.com/PlanetGamingGG/myownfreehost-mild-api-client
All the information you needed are there!
Thank you.
I checked the repository, but where is the code? There is no API client there, just documentation. The naming makes it look like it's an API client to the "mild-api-server" project. But there is no API client here and none of the methods used here are actually included in the server project.
On 8/17/2018 at 10:20 AM, PlanetCloud said:
Hello Everyone,
Quick Preview :
Thank you.
Thanks :D for using mahhost in gif image
Also, it's nice project. WHMCS don't have such functionality of checking domain whether it can be used with mofh or not. If domain can't be used with mofh then whmcs cause "Array" error.
It's nice functionality.
Edited by Aqib
