how to use cloudflare with client subdomains
if you have changed your NS to cloudflare, thats not good for reseller hosting.
Yes, you have to go through the NS of Byet for it to work.
You could aslo maybe use wildcard NS records. Simply create NS records pointing to your ns1.byet.org-ns5.byet.org with the name *.
So put the domain on cloudflare and create these records ? I don't know if this works because MOFH checks the SOA record so the root DNS records of the domain it's just enough that the domain or there are sub client domains is on cloudflare and the sites will not work anymore. After I have not tested with what you just said I may be saying nonsense.
