Need Help At MOFH Client API Installation
3 hours ago, sajidkhanrock said:
How do I can install  mofh client API on my website so there is any way to install without learning PHP
Unless you know how to code you won't be able to set it up.
I recommend you to simply add a domain selector on your registration form, and depending on what domain the user wants, redirect them to that domain signup form.
6 hours ago, sajidkhanrock said:
I know basic PHP what to do?
Learn Object-Oriented Programming!
The API client is object-oriented.
IMPORTANT: THIS LIBRARY IS AIMED AT EXPERIENCED PHP DEVELOPERS. Experience with object-oriented PHP and Composer is required. If you can't use oo-PHP and Composer, don't bother with this library.
