xost Posted October 25, 2018 Share Posted October 25, 2018 Today I became your reseller. Got logs and password in the mail. The reseller does not enter the panel. You will get an error. The reseller site has not been created. What is the problem? How to fix? Quote Link to comment Share on other sites More sharing options...
Anyx Posted October 25, 2018 Share Posted October 25, 2018 2 hours ago, xost said: Today I became your reseller. Got logs and password in the mail. The reseller does not enter the panel. You will get an error. The reseller site has not been created. What is the problem? How to fix? Could you mention your email if possible? If your email had a character like + then it will have a problem. Did you ask iFastNet Support? You can ask them and they will fix it instantly for you by either changing password or fixing the problem with the email, if one exists. Quote Link to comment Share on other sites More sharing options...
xost Posted October 25, 2018 Author Share Posted October 25, 2018 The issue with the panel was solved with the help of ifastnet support Quote Link to comment Share on other sites More sharing options...
Anyx Posted October 25, 2018 Share Posted October 25, 2018 1 hour ago, xost said: The issue with the panel was solved with the help of ifastnet support Glad to hear it! Quote Link to comment Share on other sites More sharing options...
