honeybee78 Posted December 31, 2018 Share Posted December 31, 2018 I was working on my site yesterday (navyladyveteran.com) and for some reason when I finally got it to look right (or at least the part I was working on) locally and uploaded it to hosting it no longer looked right. The menu that is. So I tried uploading it as a new install to a new sub-domain I created last night (navyladyveteran.loveslife.biz) and everything looks as it should. One of my other sites that I work on (bubbahayden.com) did a similar thing. When I uploaded the base files with the new changes it didn't take effect. However that one is correct today. Granted that site is just the base templates at the moment but the menu portion looks as I currently have it coded to look. When I look at the coding for navyladyveteran.com it is the way it should be so the code update took but if I view source on the live site it doesn't reflect the changes I made. This has happened before. I made changes to the code directly through the file manager but the live site source code didn't change. Am I missing something? Quote Link to comment Share on other sites More sharing options...
mike Posted December 31, 2018 Share Posted December 31, 2018 5 minutes ago, honeybee78 said: I was working on my site yesterday (navyladyveteran.com) and for some reason when I finally got it to look right (or at least the part I was working on) locally and uploaded it to hosting it no longer looked right. The menu that is. So I tried uploading it as a new install to a new sub-domain I created last night (navyladyveteran.loveslife.biz) and everything looks as it should. One of my other sites that I work on (bubbahayden.com) did a similar thing. When I uploaded the base files with the new changes it didn't take effect. However that one is correct today. Granted that site is just the base templates at the moment but the menu portion looks as I currently have it coded to look. When I look at the coding for navyladyveteran.com it is the way it should be so the code update took but if I view source on the live site it doesn't reflect the changes I made. This has happened before. I made changes to the code directly through the file manager but the live site source code didn't change. Am I missing something? Please try to erase your browser cache. That's probably whats causing the issue. Quote Link to comment Share on other sites More sharing options...
honeybee78 Posted December 31, 2018 Author Share Posted December 31, 2018 I did that already. I even used a different browser. A different PC as well. Quote Link to comment Share on other sites More sharing options...
honeybee78 Posted December 31, 2018 Author Share Posted December 31, 2018 I am positive It does seem to suddenly be working now. I didn't make any changes but it is now loading right Quote Link to comment Share on other sites More sharing options...
Anyx Posted January 1, 2019 Share Posted January 1, 2019 9 hours ago, ranakhas said: Both sites are working for me. And have same content init. Lol, did you check previous reply? 20 hours ago, honeybee78 said: It does seem to suddenly be working now. Quote Link to comment Share on other sites More sharing options...
