Kirill Posted September 18, 2020 Share Posted September 18, 2020 (edited) Hello, I have uploaded simple test file "index.html" using Filezilla to my site https://michurinec.byethost24.com (to "htdocs" folder) but browsers can't connect to site. How can I enable this site? Edited September 18, 2020 by Kirill Quote Link to comment Share on other sites More sharing options...
MFS Webhosting Posted September 18, 2020 Share Posted September 18, 2020 4 hours ago, Kirill said: Hello, I have uploaded simple test file "index.html" using Filezilla to my site https://michurinec.byethost24.com (to "htdocs" folder) but browsers can't connect to site. How can I enable this site? @Kirill After running a domain health check I have discovered there id an issue with the server not responding. Please contact the iFastnet Support Team at https://ifastnet.com/support and open a ticket so they can address the server failure Quote Link to comment Share on other sites More sharing options...
Kirill Posted September 19, 2020 Author Share Posted September 19, 2020 5 hours ago, 360 said: Isn't it supposed to be byethost24.org instead of a .com? Regardless, I'd suggest you open a ticket. Unfortunately "org" didn't help. Sure I have opened a ticket. Quote Link to comment Share on other sites More sharing options...
Kirill Posted September 20, 2020 Author Share Posted September 20, 2020 35 minutes ago, 360 said: Have you managed to get the problem solved? It doesn't solved yet. I have received only an answer from support: ---- Hi there,Your servers ip address is disabled for 24 hours due to a DDOS, it will be enabled again tomorrow.Thank you and stay safe !Please let us know if there is anything we can do.Best Regard ---- Quote Link to comment Share on other sites More sharing options...
