Is Byet.Host down?
50 minutes ago, supersonicstep said:
So today i wanted to work on my website and it is saying  "Site cannot be reached" For my mainsite and my test site, i have been logging in almost daily and it seems to be going on for everybody, i want to know if it is really down?
My sites and others are working normally what is the name of your site?
Hi supersonicstep,
A good method to know if your site is down, is to check it in sites like https://isitup.org/, or https://www.isitdownrightnow.com/ . You just have to write your website URL, and they will tell you if your website is really down, or if it's only you.
My sites have not gone down. Still up and working. I would say it may be because of some bad code but if it's more than one person experiencing this issue then it must be more than that. They may or may not be experiencing some over load on their servers since I have though notice that it something takes awhile for my sites to load. I recomment contacting https://support.ifastnet.com for more info or just wait a bit to see if issue has been resolved. Another cause of this they may be doing some maintenance or getting a DOS attack like 2 weeks ago.
Hope this helped! If it did leave a like!
This topic is now closed to further replies.
