How to modify or remove tutorials link in cPanel
AA22Dev
14 hours ago, PlanetCloud said:
I belive that can be done using JS but I had lost track of the file to modify it...
You can try to experiment with JS and I think it's preety straightforward process.
I had tried to use JS but it create another block of support.
9 hours ago, PlanetCloud said:
Here's what I've used :
foreach(document.querySelectorAll('a[href^="https://tutorials.securesignup.net"]'), function(t) {
    t.setAttribute("href", "TUTORIAL_DOMAIN_HERE")
Make sure everything is loaded first, then run the script.
It will look something like this :
window.onload = function(e){
Hope this helps.
ok, thanks. Seems like i have to use it in footer
Hope this helps.
This code is not working
Make sure you have waited around 15-30 min since you saved the code in the footer ( it usually takes this long to update the code ). Also, check your cache, just in case it's that.
Ok, thanks i will check it.
This code is still not working. I waited alot after putting this code. I am using the latest version of chrome. I also try Microsoft Edge.
5 minutes ago, PlanetCloud said:
Have you checked the source and make sure that the code is in place?
Also to my knowledge, that code will only appear to user that registered POST adding the script.
Yes, the code is present in the footer.
I added this code
<script type"javascript">
        t.setAttribute("href", "https://portal.mahhost.win/index.php?rp=/knowledgebase")
</script>
<script type="javascript">
        t.setAttribute("href", "https://example.com")
</script>
10 hours ago, PlanetCloud said:
Try checking your console (F12/Inspector -> Console) and see if there's any error logged.
These are error logged in my console window
Failed to load resource: the server responded with a status of 404 (Not Found)
2indexpl.php?id=9c4fa294b447dcb6d91f83c87210b75c71eb4727:736 A parser-blocking, cross site (i.e. different eTLD+1) script, https://secure.statcounter.com/counter/counter.js, is invoked via document.write. The network request for this script MAY be blocked by the browser in this or a future page load due to poor network connectivity. If blocked in this page load, it will be confirmed in a subsequent console message. See https://www.chromestatus.com/feature/5718547946799104 for more details.
(anonymous) @ indexpl.php?id=9c4fa294b447dcb6d91f83c87210b75c71eb4727:736
/execute/Notifications/get_notifications_count?cache-fix=0.3257630838685297 Failed to load resource: the server responded with a status of 404 (Not Found)
But they have nothing to relate with that script
This topic is now closed to further replies.
