luluhoste Posted July 12, 2023 Share Posted July 12, 2023 Peut on utiliser Wordpress pour le site d' accueil ? ---trad google--- Can we use Wordpress for the home site ? Quote Link to comment Share on other sites More sharing options...
PlanetCloud Posted July 12, 2023 Share Posted July 12, 2023 1 hour ago, luluhoste said: Peut on utiliser Wordpress pour le site d' accueil ? ---trad google--- Can we use Wordpress for the home site ? Yes you can use WordPress as your main site while maintaining MOFH features. Just make sure you have your forms setted up correctly or use LOGGED which can be used alongside WordPress. Quote Link to comment Share on other sites More sharing options...
luluhoste Posted July 12, 2023 Author Share Posted July 12, 2023 que veut dire : 29 minutes ago, PlanetCloud said: Assurez-vous simplement que vos formulaires sont correctement configurés ---trad google--- What means : 29 minutes ago, PlanetCloud said: Just make sure you have your forms setted up correctly Quote Link to comment Share on other sites More sharing options...
PlanetCloud Posted July 12, 2023 Share Posted July 12, 2023 Just now, luluhoste said: que veut dire : ---trad google--- What means : The signup form for MyOwnFreeHost must be located at /signup.php which may or may not work with WordPress. Quote Link to comment Share on other sites More sharing options...
luluhoste Posted July 12, 2023 Author Share Posted July 12, 2023 et ceci c'est quoi ? 32 minutes ago, PlanetCloud said: utilisez LOGGED qui peut être utilisé avec WordPress. ---trad google--- and this is what ? 32 minutes ago, PlanetCloud said: use LOGGED which can be used alongside WordPress. Quote Link to comment Share on other sites More sharing options...
PlanetCloud Posted July 12, 2023 Share Posted July 12, 2023 Just now, luluhoste said: et ceci c'est quoi ? ---trad google--- and this is what ? Project LOGGED can be installed alongside WordPress*, in case you are planning to use a regular signup form instead of a client area. *supposedly Quote Link to comment Share on other sites More sharing options...
luluhoste Posted July 12, 2023 Author Share Posted July 12, 2023 si je prend , disons, xera comme espace client, avec WordPress, cela fonctionne ? ---trad google--- if I take, say, xera as customer area , with WordPress, does it work ? Quote Link to comment Share on other sites More sharing options...
PlanetCloud Posted July 12, 2023 Share Posted July 12, 2023 3 minutes ago, luluhoste said: if I take, say, xera as customer area , with WordPress, does it work ? Unfortunately, I'm not quite sure as I never used Xera before. You'll need to check how Xera works and determine if it is compatible with WordPress or not. Quote Link to comment Share on other sites More sharing options...
luluhoste Posted July 12, 2023 Author Share Posted July 12, 2023 pas que Xera, un espace client quelconque, comme vous disiez ceci : il y a 12 minutes, PlanetCloud a dit : Le projet LOGGED peut être installé avec WordPress*, au cas où vous envisagez d'utiliser un formulaire d'inscription standard au lieu d'un espace client. Comme si je pouvait me passer du projet LOGGED ci j'ai un espace client... ---trad google--- not just Xera, a client area any, as you said this : 14 minutes ago, PlanetCloud said: Le projet LOGGED peut être installé avec WordPress*, au cas où vous envisagez d'utiliser un formulaire d'inscription standard au lieu d'un espace client. As if I could do without the LOGGED project here I have a customer area... Quote Link to comment Share on other sites More sharing options...
TinkerMan Posted July 12, 2023 Share Posted July 12, 2023 Project LOGGED is not a client area, Xera is. WordPress and Xera won’t work together, as they would both be trying to do the same thing (I mean you could integrate Xera into WordPress theoretically). And please, can you read the README files on the GitHub projects we are linking to? Most of the questions you are asking can be resolved just by reading that one page. Quote Link to comment Share on other sites More sharing options...
SpookyKipper Posted July 13, 2023 Share Posted July 13, 2023 (edited) 6 hours ago, TinkerMan said: (I mean you could integrate Xera into WordPress theoretically). If WordPress supports OAuth, you can, or, internal passwords, TinkerHost seems to be doing that for the forum, but make sure those are secure if you do it I have successfully linked NamelessMC Accounts to Xera using OAuth2 I can't remove the emoji below 🫠 Edited July 13, 2023 by SpookyKipper Quote Link to comment Share on other sites More sharing options...
luluhoste Posted July 14, 2023 Author Share Posted July 14, 2023 Sinon, pour faire le site d'accueil, il faut le codé en HTML ? ---trad google--- Otherwise, to make the home site, it must be coded in HTML ? Quote Link to comment Share on other sites More sharing options...
TinkerMan Posted July 14, 2023 Share Posted July 14, 2023 I mean, yes. HTML is the only frontend language you can use. If you want to use PHP for backend, that’s totally fine as well. Quote Link to comment Share on other sites More sharing options...
TinkerMan Posted July 14, 2023 Share Posted July 14, 2023 Just make sure that if you are not using a ClientArea, but the default MOFH signup system, you keep this in mind: On 7/12/2023 at 12:21 PM, PlanetCloud said: The signup form for MyOwnFreeHost must be located at /signup.php Quote Link to comment Share on other sites More sharing options...
luluhoste Posted July 14, 2023 Author Share Posted July 14, 2023 Un grand merci 😄 ---trad google--- A big thank-you 😄 Quote Link to comment Share on other sites More sharing options...
