luluhoste Posted July 23, 2023 Share Posted July 23, 2023 Salut Commenr réparer le SSL de GenerateArea ? ---trad googlr--- Hi How to fix GenerateArea SSL ? Quote Link to comment Share on other sites More sharing options...
TinkerMan Posted July 23, 2023 Share Posted July 23, 2023 Use the files from Xera to patch it. I know others have done it and it works. (I won’t be able to help you with this one, I’ve never used either of these platforms) Quote Link to comment Share on other sites More sharing options...
SpookyKipper Posted July 23, 2023 Share Posted July 23, 2023 (edited) i have no idea what I said a few weeks ago(on discord) but apparently this is how to fix that for GA: /template/(default)/user/createssl.php Make the dname to be a textarea the name will be "csr" /app/models/GoGetSSL.php replace it with Xera's /app/controllers/U.php replace the create SSL function with Xera's Edited July 23, 2023 by SpookyKipper Quote Link to comment Share on other sites More sharing options...
luluhoste Posted July 24, 2023 Author Share Posted July 24, 2023 Super !!!, merci, je vais essayer ! ---trad google--- Great !!!, thank you, I'll give it a try ! Quote Link to comment Share on other sites More sharing options...
luluhoste Posted July 24, 2023 Author Share Posted July 24, 2023 On 7/23/2023 at 3:15 PM, SpookyKipper said: i have no idea what I said a few weeks ago(on discord) but apparently this is how to fix that for GA: /template/(default)/user/createssl.php Make the dname to be a textarea the name will be "csr" /app/models/GoGetSSL.php replace it with Xera's /app/controllers/U.php replace the create SSL function with Xera's J'ai fait cela et tous fonctionne ! Merci @SpookyKipper 😄 ---trad google--- I did this and it all works ! Thank you @SpookyKipper 😄 Quote Link to comment Share on other sites More sharing options...
