Forum : flarum
luluhoste
Bonjour à tous 🖐️
Est il possible d'installer Flarum sur l'hébergement lier au compte MOFH ?
Et quel est la version de "  Composer" qui est installé ? (si il y en a une 😅)
---trad google---
Hello everyone 🖐️
Is it possible to install Flarum on the hosting linked to the MOFH account?
And what is the version of "Composer" which is installed ? (if there is one 😅)
Edited by luluhoste
Just now, luluhoste said:
And @TinkerMan in Flarum ? and @SpookyKipper had this before ? was it hosted elsewhere than on ifastnet ?
TinkerMan has his own server, and non of tinkerhost's custom stuff was hosted on ifastnet.
for me, I used freeflarum (and i paid them 7 euros to remove their branding for lifetime). but now i don't use it anymore
3 hours ago, SpookyKipper said:
everyone on mofh can't get flarum working
I could never get it working through softaculous, but installing it locally via composer was possible (At least 3-6 months ago, who knows if it still works). You would certainly have to use an older version though, and check dependency requirements.
Wait, it’s that cheap? If I didn’t have my own server that would be a good deal …
7 hours ago, luluhoste said:
ha, ok, And is there "composer" ???
Yes. Flarum is best installed through Composer; after Composer has generated the dependencies, you should be able to upload the files to your hosting account and install Flarum. I'm unsure if it works well, though.
They have some 10 minute downtime occasionally,  and you cannot install your own extensions. They pre installed a bunch of them, but if you want one you can suggest one to them
