Composer
luluhoste
1 hour ago, luluhoste said:
has Composer been added?
What do you mean?
Composer could be used with PHP 7.4 and now with PHP 8.2 as far as I'm aware. You just need to perform the installation locally first, then upload the resulting files to the server.
C'est parce que il y a un dossier dans le FTP qui porte le nom de "rakit" > "validation" > "composer.json".
Alors c'est pour cela que je pose la question.
Et, au passage, avez vous la même chose ?
---trad google---
This is because there is a folder in the FTP called "rakit" > "validation" > "composer.json".
So that's why I'm asking the question.
And, by the way, do you have the same thing ?
Edited by luluhoste
Dans le FTP, il y a un dossier nommé « rakit » avec dedans « validation » et encore dedans « composer.json »...
Donc, la question est : c'est quoi se dossier avec son contenu ?
---trad google---
In the FTP, there is a folder named “rakit” with “validation” inside and again “composer.json”...
So, the question is: what is the folder with its contents ?
---trad google---
My guess is the php packages?
