Mofh-r est KO ! / Mofh-r is KO !
luluhoste
Salut 😄
Je crois que Mofh-r est définitivement mort avec PHP 8 😉😵 !
Il affiche des tas d'erreurs , du type de celle-ci :
A PHP Error was encountered
Severity: 8192
Message: Creation of dynamic property CI_URI::$config is deprecated
Filename: core/URI.php
Line Number: 101
Backtrace:
File: /.../censurer/...
Line: 315
Function: require_once
Voila, Je pense que tous le monde qui utilise Mofh-r ont le même problème ?
---trad google---
Hi 😄
I think Mofh-r is definitely dead with PHP 8 😉 😵!
It displays lots of errors, like this:
Severity: 8192
Line Number: 101
Backtrace:
File: /.../censorship/...
Line: 315
There you go, I think everyone who uses Mofh-r has the same problem ?
Edited by luluhoste
Supprimé URL
I've updated MOFH-R to the latest CodeIgniter and PHP 8.2; it is available for download at https://github.com/ActiveMaintenance/MOFH-R
No guarantees, however. MOFH-R is no longer developed by its original developer, who is now developing Xera, and is considered abandoned. I would not recommend continuing to use it long-term unless you also plan to continue developing it and ensuring no security vulnerabilities can affect it.
