RapidFreeHost Review!
Cyberdog
  • Cyberdog changed the title to RapidFreeHost Review!
1. Site loads slow
2. You spelt benefit wrong
3. You spelt completely wrong
4. What is best speed?
5. What is 100% secured?
6. Social media links don't work
7. "Enjoy all the features" in the free plan is NOT TRUE and is false advertising.
8. The images you show on the page is NOT your actual UI and is false advertising.
Edited by SpookyKipper
31 minutes ago, luluhoste said:
Salut
Pas trop mal, mais le style de la page d'accueil est un peut banale et ennuyeux...
---trad google---
Hi
Not too bad, but the style of the home page is a bit banal and boring...
Thanks for the review, I appreciate that I will try to update it!
31 minutes ago, SpookyKipper said:
1. Site loads slow
1. Is working on fixing it.
2. Fixed
3. Fixed
4. that means best speed optimized for free hosting. (fixed)
5. It was 100% uptime Garentuee i changed the value (fixed)
6. It will come soon.
7. "Enjoy all the features" in the free plan is not false advertising it means the features available on the free plan not the features of premium plans I updated it for better understanding (fixed).
8. The image was for demo purpose it will be changed soon.
Thanks for the reviews. I appreciate that thanks!
Scrolling on the homepage does not work on mobile
”Enjoy uninterrupted service” simply not true
The “read more” button does not work
The orange loading dial does not fit the brand colors at all
It’s really weird that half the site is written in broken English, and the other half is pretty clearly written by AI. I think you should find some middle ground here, or at least make it consistent
In the pricing table:
”Support” should be capitalized
You can have unlimited websites on the free plan, you are only restricted to the number of hosting accounts. Similar on paid plans (website limitations are much higher then account limitations)
Gigabyte should be plural (5>1)
It’s “MySQL”
All PHP versions are not available on premium hosting (to my knowledge at least)
should be “safe and secure” not “secured”
You still don’t have a link back to iFN which is a terms violation
“Help customer” on the about page does not make any sense. Maybe “customer support”?
It’s “MySQL”
”Support” should be capitalized - done
You can have unlimited websites on the free plan, you are only restricted to the number of hosting accounts. Similar on paid plans (website limitations are much higher then account limitations) - done
Gigabyte should be plural (5>1) - done
It’s “MySQL” - done
should be “safe and secure” not “secured” - done
You still don’t have a link back to iFN which is a terms violation - done
“Help customer” on the about page does not make any sense. Maybe “customer support”? - done
hello, thanks for the review that was very helpful appreciate that I have fixed all of the suggestions posted above.
53 minutes ago, luluhoste said:
Super, le nouveau look est mieux; tu a tous codé ou c'est un template ?
---trad google---
Great, the new look is better;  did you code them all or is it a template ?
Thank you very much for your valuable reply. This is a premium template that I customized to suit my needs. I appreciate your response!
