Domain is not opening
Karlos
Good afternoon,
guys my domain is directed to ns1.byet.org & ns2.byet.org
however, domain is not opening and keep redirected to ww0.
I'm sure the name server changed inside the domain control panel.
any suggestions?
edit: i opened the domain from mobile and it works fine, registration and subdomains, how to change the users prefix?
Edited by Karlos
update
You can’t.
if you add another domain to the account you will be able to set the prefix for that domain. You can’t set the prefix for the first domain, and the prefix cannot be changed after it is setup.
On 8/25/2024 at 11:52 PM, TinkerMan said:
You can’t.
Thank you TinkerMan
Edited by Lemon
You can’t.
I got the Idea and my domain is working fine now, i have installed SSL and roaming around in my reseller panel.
I wonder how to add SSL to my vista panel url as well?
why the CNAME are not working? I'm trying to activate google search console and Verify domain ownership via DNS record using CNAME
And what are the benefits of reseller API and how to use it? I read the documentation but all it says is add IP
You can’t. It should be done automatically. If it is not there in a few days, ask iFN.
Did you add them in the vpanel account you were given for the domain? Refresh the page and make sure they are still there.
You can create your own client area. See app.tinkerhost.net for an example.
For setup, see the docs at
https://api.myownfreehost.net
