sajidkhanrock Posted August 31, 2018 Share Posted August 31, 2018 Can Any Make mofh client for me or any have like infinityfree Quote Link to comment Share on other sites More sharing options...
AA22Dev Posted August 31, 2018 Share Posted August 31, 2018 (edited) 26 minutes ago, sajidkhanrock said: Can Any Make mofh client for me or any have like infinityfree @PlanetCloud is creating a project logged which will be a client area i think. Edited August 31, 2018 by Aqib Quote Link to comment Share on other sites More sharing options...
PlanetCloud Posted August 31, 2018 Share Posted August 31, 2018 31 minutes ago, Aqib said: @PlanetCloud is creating a project logged which will be a client area i think. Hi @Aqib, Project LOGGED will NOT be a client area but just a login, signup and reset password template. 58 minutes ago, sajidkhanrock said: Can Any Make mofh client for me or any have like infinityfree For you? Why should we? A client area is complicated to develop. It may look simple but when you look a bit closer, it's more complicated than you think. You can actually make your own client area and I belive by following these tutorial, you can create your own client area. For the front-end : HTML & CSS (Required) : Javascript (Optional) : Javascript Angular Framework (Optional) : For the backend : PHP (Required) : Object-Oriented PHP (Required) : Design Patterns (Recomended) : https://www.google.com/search?safe=strict&rlz=1C1CHWL_enID774ID774&ei=YB6JW4m8FdPLrQHfs5ewDw&q=software+design+patterns&oq=softwadesign+patterns&gs_l=psy-ab.3.0.0i7i30k1l10.3512.5376.0.6060.8.6.2.0.0.0.100.539.5j1.6.0....0...1c.1.64.psy-ab..0.8.542....0.y6J-KLoYmLw Of course you may do a Google Search for more details on a specific topics. I've watched everything in the playlists above (Excepct Angular JS Crash Course and Javascript because I've learned it elsewhere) and I think it's a good way to start. Also this topic should not be called "MOFH Client Setup" as the content/question is irrelevant. Quote Link to comment Share on other sites More sharing options...
Anyx Posted August 31, 2018 Share Posted August 31, 2018 @sajidkhanrock @PlanetCloud is developing a client area, QUID, however it will take time since it is finished because he's busy too. Quote Link to comment Share on other sites More sharing options...
AA22Dev Posted August 31, 2018 Share Posted August 31, 2018 21 minutes ago, PlanetCloud said: Hi @Aqib, Project LOGGED will NOT be a client area but just a login, signup and reset password template. Ahhh... okay! it's project quid developed by you which will be client area. I forgot Quote Link to comment Share on other sites More sharing options...
sajidkhanrock Posted August 31, 2018 Author Share Posted August 31, 2018 When the QUID launch is it free Quote Link to comment Share on other sites More sharing options...
sajidkhanrock Posted August 31, 2018 Author Share Posted August 31, 2018 When I try To create Account with example code it shows error Fatal error: Uncaught Error: Class 'HansAdema\MofhClient\Client' not found in E:\Sajd\xammp\htdocs\host\index.php:10 Stack trace: #0 {main} thrown in E:\Sajd\xammp\htdocs\host\index.php on line 10 Quote Link to comment Share on other sites More sharing options...
PlanetCloud Posted September 1, 2018 Share Posted September 1, 2018 10 hours ago, sajidkhanrock said: When I try To create Account with example code it shows error Fatal error: Uncaught Error: Class 'HansAdema\MofhClient\Client' not found in E:\Sajd\xammp\htdocs\host\index.php:10 Stack trace: #0 {main} thrown in E:\Sajd\xammp\htdocs\host\index.php on line 10 The error is very clear and you should be able to fix it if you watched my recomended videos above Quote Link to comment Share on other sites More sharing options...
Mauwiks Posted September 4, 2018 Share Posted September 4, 2018 On 8/31/2018 at 6:57 PM, PlanetCloud said: Hi @Aqib, Project LOGGED will NOT be a client area but just a login, signup and reset password template. For you? Why should we? A client area is complicated to develop. It may look simple but when you look a bit closer, it's more complicated than you think. You can actually make your own client area and I belive by following these tutorial, you can create your own client area. For the front-end : HTML & CSS (Required) : Javascript (Optional) : Javascript Angular Framework (Optional) : For the backend : PHP (Required) : Object-Oriented PHP (Required) : Design Patterns (Recomended) : https://www.google.com/search?safe=strict&rlz=1C1CHWL_enID774ID774&ei=YB6JW4m8FdPLrQHfs5ewDw&q=software+design+patterns&oq=softwadesign+patterns&gs_l=psy-ab.3.0.0i7i30k1l10.3512.5376.0.6060.8.6.2.0.0.0.100.539.5j1.6.0....0...1c.1.64.psy-ab..0.8.542....0.y6J-KLoYmLw Of course you may do a Google Search for more details on a specific topics. I've watched everything in the playlists above (Excepct Angular JS Crash Course and Javascript because I've learned it elsewhere) and I think it's a good way to start. Also this topic should not be called "MOFH Client Setup" as the content/question is irrelevant. Thanks @PlanetCloud Quote Link to comment Share on other sites More sharing options...
einet Posted September 4, 2018 Share Posted September 4, 2018 On 31/8/2018 at 10:54 AM, sajidkhanrock said: When I try To create Account with example code it shows error Fatal error: Uncaught Error: Class 'HansAdema\MofhClient\Client' not found in E:\Sajd\xammp\htdocs\host\index.php:10 Stack trace: #0 {main} thrown in E:\Sajd\xammp\htdocs\host\index.php on line 10 Remember that you must add your ip address to your reseller account from where you will be executing the script accounts with 5 available functions in this script 1. domain verification. 2. hosting account creation. 3. account suspension 4. Update or change password 5. Reactivation of account disabled by the same user you must take into account that for the creation of account in the name of being maximum 8 characters you can create or use a random name generator for this. The functions are marked with 2 // as an example of how it is used to call it from the script, I remind you to work a little to get what you want. I would like to help but I do not have much time available. the script or library and I have sent it to your email regards Quote Link to comment Share on other sites More sharing options...
sajidkhanrock Posted September 5, 2018 Author Share Posted September 5, 2018 @einet when I upload Script "mofh complete" then it shows error 500 what to do Quote Link to comment Share on other sites More sharing options...
Anyx Posted September 5, 2018 Share Posted September 5, 2018 3 hours ago, sajidkhanrock said: @einet when I upload Script "mofh complete" then it shows error 500 what to do I will quote @einet's reply here: On 4/9/2018 at 7:21 AM, einet said: Remember that you must add your ip address to your reseller account from where you will be executing the script accounts with 5 available functions in this script 1. domain verification. 2. hosting account creation. 3. account suspension 4. Update or change password 5. Reactivation of account disabled by the same user you must take into account that for the creation of account in the name of being maximum 8 characters you can create or use a random name generator for this. The functions are marked with 2 // as an example of how it is used to call it from the script, I remind you to work a little to get what you want. I would like to help but I do not have much time available. the script or library and I have sent it to your email regards Did you follow these instructions? Quote Link to comment Share on other sites More sharing options...
sajidkhanrock Posted September 5, 2018 Author Share Posted September 5, 2018 Yes but when i go to create a account then it shows error 500 but domain check works Quote Link to comment Share on other sites More sharing options...
Anyx Posted September 5, 2018 Share Posted September 5, 2018 23 minutes ago, sajidkhanrock said: Yes but when i go to create a account then it shows error 500 but domain check works Okay, got it. @einet can help when back, in the meantime have you verified that API Username/Password/API Allowed Address are correct? Quote Link to comment Share on other sites More sharing options...
sajidkhanrock Posted September 5, 2018 Author Share Posted September 5, 2018 Yes All are correct Quote Link to comment Share on other sites More sharing options...
AA22Dev Posted September 5, 2018 Share Posted September 5, 2018 6 hours ago, sajidkhanrock said: Yes All are correct Had you modified .htaccess file? had you added YOur Server iP Address in MOFH Allowed IP Address? Quote Link to comment Share on other sites More sharing options...
sajidkhanrock Posted September 5, 2018 Author Share Posted September 5, 2018 Yes But when i create account it shows error 500 but domain checker working ok Quote Link to comment Share on other sites More sharing options...
AA22Dev Posted September 5, 2018 Share Posted September 5, 2018 2 hours ago, sajidkhanrock said: Yes But when i create account it shows error 500 but domain checker working ok Had you answered okay for both question's? Quote Link to comment Share on other sites More sharing options...
PlanetCloud Posted September 6, 2018 Share Posted September 6, 2018 (edited) Hi there, Just enable Show Error and you should be able to see the problem and hopefully fix. Edited September 6, 2018 by PlanetCloud Quote Link to comment Share on other sites More sharing options...
sajidkhanrock Posted September 6, 2018 Author Share Posted September 6, 2018 I will check error log that einet provided thanks for suggesting Quote Link to comment Share on other sites More sharing options...
einet Posted September 27, 2018 Share Posted September 27, 2018 I will have to make a video of how to put the script to work (FOR TESTS) so you can execute the orders in a simpler way the problem will be to upload the video since my internet is a bit slower, and make official the use of mofh for developers so I can give you the idea (I'll try) Quote Link to comment Share on other sites More sharing options...
PlanetCloud Posted September 28, 2018 Share Posted September 28, 2018 21 hours ago, einet said: I will have to make a video of how to put the script to work (FOR TESTS) so you can execute the orders in a simpler way the problem will be to upload the video since my internet is a bit slower, and make official the use of mofh for developers so I can give you the idea (I'll try) No need to! All you have to learn is just PHP and Object Oriented Programming and you are all set! The documentation here https://github.com/HansAdema/mofh-client/blob/master/README.md is enough and more methods can be founded on https://github.com/HansAdema/mofh-client/tree/master/src/Message. Quote Link to comment Share on other sites More sharing options...
Anyx Posted September 28, 2018 Share Posted September 28, 2018 8 hours ago, PlanetCloud said: No need to! All you have to learn is just PHP and Object Oriented Programming and you are all set! The documentation here https://github.com/HansAdema/mofh-client/blob/master/README.md is enough and more methods can be founded on https://github.com/HansAdema/mofh-client/tree/master/src/Message. Why not? We don't have all the time to learn OO-PHP, so this video could help us and even new potential MOFH users. BTW @einet is your complete version same as the July update of Hans? Quote Link to comment Share on other sites More sharing options...
Anyx Posted September 28, 2018 Share Posted September 28, 2018 1 hour ago, ranakhas said: If you want to get something you have to lose something! Providing time to learn is no big issue ! Agreed, however why not make the video if @einet wants to? Quote Link to comment Share on other sites More sharing options...
PlanetCloud Posted September 29, 2018 Share Posted September 29, 2018 14 hours ago, PCTipsGR said: Why not? We don't have all the time to learn OO-PHP, so this video could help us and even new potential MOFH users. BTW @einet is your complete version same as the July update of Hans? Dude... even with tutorial video's, it's almost not practical if you don't learn OOP because when you got stuck to an error, what are you going to do? Just Google it? And hope that you could easily copy and paste the answer? Are this https://github.com/HansAdema/mofh-client not clear enough? Literary type this : use \HansAdema\MofhClient\Client; // Create a new API client with your API credentials. $client = Client::create([ 'apiUsername' => 'your_api_username', 'apiPassword' => 'your_api_password', 'plan' => 'my_plan', // Optional, you can define it here or define it with the createAccount call. ]); // Create a request object to create the request. $request = $client->createAccount([ 'username' => 'abcdefgh', // A unique, 8 character identifier of the account. 'password' => 'password123', // A password to login to the control panel, FTP and databases. 'domain' => 'userdomain.example.com', // Can be a subdomain or a custom domain. 'email' => '[email protected]', // The email address of the user. 'plan' => 'my_plan', // Optional, you can submit a hosting plan here or with the Client instantiation. ]); // Send the API request and keep the response. $response = $request->send(); // Check whether the request was successful. if ($response->isSuccessful()) { echo 'You can login as: ' . $response->getVpUsername(); } else { echo 'Failed to create account: ' . $response->getMessage(); } And you had successfully created an account (Without email verification)! At one point, project LOGGED uses this API system but because it lacks email verification and Byet's mail() is limited, it was scrapped. Quote Link to comment Share on other sites More sharing options...
