Kamalard232 Posted April 24, 2022 Share Posted April 24, 2022 How can I make Cpanel and Client Portal for Free? Quote Link to comment Share on other sites More sharing options...
smallhost Posted April 24, 2022 Share Posted April 24, 2022 Hello! From the context provided in this post, I assume you're using MyOwnFreeHost (MOFH). All MOFH providers have built-in cPanel pre-configured, just type cpanel. before your host's URL (for example, cpanel.smallhost.us.to is the SmallHost cPanel and cpanel.epizy.com is InfinityFree's cPanel). You can edit some things on the cPanel on the MOFH Admin panel at panel.myownfreehost.net To make a client portal, you either need to make your own or use a pre-built one like MOFHY Lite. I recommend making your own as it gives you more control, however using a pre-built one is good for beginners. Quote Link to comment Share on other sites More sharing options...
TinkerMan Posted April 24, 2022 Share Posted April 24, 2022 A control panel is already included like @smallhost stated. I DONT RECOMMEND that you use MOFHY-Lite, as it is not secure, and can be hacked easily. Currently, the only secure system for MOFH is Project LOGGED, which is a signup system. Building your own client portal is recommended. Quote Link to comment Share on other sites More sharing options...
