MOFH Callback Client Library - Handle Callbacks from MOFH Like a Pro, For Client Areas
PlanetCloud
  • PlanetCloud changed the title to MOFH Callback Client Library - Handle Callbacks from MOFH Like a Pro, For Client Areas
For Entry Process Limit:       {"username":"uname_xxxxxxxx","status":"SUSPENDED","comments":"ADMIN_CLOSE : DAILY_ ep"}
For Daily Hits:     {"username":"uname_xxxxxxxx","status":"SUSPENDED","comments":"ADMIN_CLOSE : DAILY_HIT;"}
For CPU Limit:       {"username":"uname_xxxxxxxx","status":"SUSPENDED","comments":"ADMIN_CLOSE : DAILY_ cpu"}
For Inactive Account:        {"username":"uname_xxxxxxxx","status":"SUSPENDED","comments":"AUTO_IDLE;"} !!!This is the only one I am 99% sure on, the rest are correct!!!!
Hope this helps!
I noticed for the comments, if there are multiple suspension history, we'll receive it all like this:
OTHER_CLOSE; REQUESTED OTHER_CLOSE; OTHER_CLOSE; NULLED_SCRIPT
Is this always the case or only for manual intervention/suspension?
11 minutes ago, RoyalityFree said:
all responses i recorded from mofh till now.
I would love to get that data and I believe it should be shared privately (because it contains usernames) or you can remove the usernames first and share it here.
It would be very helpful indeed.
Yes. Is know there are thinks like “Linked to” and “ADMIN CLOSE” and “RES CLOSE”, but I have yet to determine if they are auto-sent or based on actual admin action.
Since the reason for suspension comes in many shapes and sizes, I believe I shouldn't add a specific handler for each. Just onAccountSuspended is enough. For the reason, it is recommended that it is logged/saved to database along with the account. Sometimes the same reason for example "Disposable email" comes in the following format: DISPOSABLE_EMAIL and "disposable email protonmail.com". Would be hellish to code for each scenario.
So a reseller could tell their clients that they were suspended because of x, otherwise they will come to whatever support channel you have an go “Why am I suspended???  I want my account back!!! I did nothing worng! Please?
my fairly accurate representation of an annoyed clieny.
