TinkerMan Posted May 4, 2022 Share Posted May 4, 2022 (edited) I have used vPanel for over a year, and literally just noticed this today. Is this something that people just don't talk about, is it something no one wants to fix, or is it something no one has noticed? Look on the left side of the image. About one-third of the lines are different from the rest. Can you figure out what is wrong? If no one gets it, I'll post it in a few hours so the developers can hopefully fix it (It will drive you nuts once you find it). And then in the code, this little gem was found: <div="group=" " in=" " applicationlist=" " track=" " by=" " group.group"=""> I am 99.99% certain that is not valid HTML Also, can someone tell the developers that an ID should only be used once in HTML (Not that big of a deal, but still)? That's all for now Edited May 4, 2022 by TinkerMan Upped my percentage :) Link to comment Share on other sites More sharing options...
Dimitris Posted May 5, 2022 Share Posted May 5, 2022 I would suggest to report this to directly to iFastNet instead of the forum. Link to comment Share on other sites More sharing options...
TinkerMan Posted May 5, 2022 Author Share Posted May 5, 2022 Will do. If you dident spot it yet, its the colons ":". Link to comment Share on other sites More sharing options...
TinkerMan Posted May 5, 2022 Author Share Posted May 5, 2022 Reported to them, let's see what they say Link to comment Share on other sites More sharing options...
TinkerMan Posted May 6, 2022 Author Share Posted May 6, 2022 Update: The simicolons have been fixed. Link to comment Share on other sites More sharing options...
PlanetCloud Posted May 6, 2022 Share Posted May 6, 2022 37 minutes ago, TinkerMan said: Update: The simicolons have been fixed. By the Support team? Link to comment Share on other sites More sharing options...
TinkerMan Posted May 6, 2022 Author Share Posted May 6, 2022 No, I hacked the system and fixed it myself (Yes, by the support team) Link to comment Share on other sites More sharing options...
Dimitris Posted May 6, 2022 Share Posted May 6, 2022 Glad to see that was fixed. I consider this problem resolved and I'm locking the topic. Link to comment Share on other sites More sharing options...
