Mahtab Hassan Posted February 16, 2022 Author Share Posted February 16, 2022 On 2/14/2022 at 1:46 AM, User51 said: Also, SitePro integration would be nice. Site.pro integration will be available in up comming week Quote Link to comment Share on other sites More sharing options...
Mahtab Hassan Posted February 16, 2022 Author Share Posted February 16, 2022 On 2/14/2022 at 1:46 AM, User51 said: Also, SitePro integration would be nice. Can you tell me a secure login system? Quote Link to comment Share on other sites More sharing options...
MeTooIDK Posted February 17, 2022 Share Posted February 17, 2022 21 hours ago, Shen Wei said: Can you tell me a secure login system? what is SecureLogin? Quote Link to comment Share on other sites More sharing options...
Mahtab Hassan Posted February 17, 2022 Author Share Posted February 17, 2022 3 hours ago, MeTooIDK said: what is SecureLogin? Well secure login means using a custom token to generate a cookie for user login Quote Link to comment Share on other sites More sharing options...
Mahtab Hassan Posted February 17, 2022 Author Share Posted February 17, 2022 Applied fixes: Admin ui. User activate and suspend feature. Ticket close by admin feature. Site.pro api setting added. User login session updated. Quote Link to comment Share on other sites More sharing options...
TinkerMan Posted February 17, 2022 Share Posted February 17, 2022 15 minutes ago, Shen Wei said: Site.pro api setting added. I don't see the integration, is it not ready yet? Quote Link to comment Share on other sites More sharing options...
Mahtab Hassan Posted February 18, 2022 Author Share Posted February 18, 2022 11 hours ago, TinkerMan said: I don't see the integration, is it not ready yet? Only api setting added integration wiol be added Quote Link to comment Share on other sites More sharing options...
Mahtab Hassan Posted February 18, 2022 Author Share Posted February 18, 2022 Ui fixes added Quote Link to comment Share on other sites More sharing options...
JaiktDev Posted March 3, 2022 Share Posted March 3, 2022 Update MyAccounts.php by jaikt · Pull Request #89 · NXTS-Developers/MOFHY-Lite (github.com) Quote Link to comment Share on other sites More sharing options...
rukitinc Posted April 16, 2022 Share Posted April 16, 2022 ERROR :The API key you are using appears to be invalid 1. . How to fix Quote Link to comment Share on other sites More sharing options...
TinkerMan Posted April 16, 2022 Share Posted April 16, 2022 Please don’t use MOFHY, it is very easy for your Admin area, as well as your clients to be hacked. And the error message is quite clear, the API key is incorrect. Quote Link to comment Share on other sites More sharing options...
rukitinc Posted April 16, 2022 Share Posted April 16, 2022 24 minutes ago, TinkerMan said: Please don’t use MOFHY, it is very easy for your Admin area, as well as your clients to be hacked. And the error message is quite clear, the API key is incorrect. Api keys is correct Quote Link to comment Share on other sites More sharing options...
JaiktDev Posted April 17, 2022 Share Posted April 17, 2022 10 hours ago, rukitinc said: Api keys is correct make sure no spaces are there Quote Link to comment Share on other sites More sharing options...
rukitinc Posted April 17, 2022 Share Posted April 17, 2022 7 minutes ago, RoyalityFree said: make sure no spaces are there i'am sure Quote Link to comment Share on other sites More sharing options...
Mahtab Hassan Posted April 17, 2022 Author Share Posted April 17, 2022 5 hours ago, rukitinc said: i'am sure Check if the api username and api password is correct. Quote Link to comment Share on other sites More sharing options...
rukitinc Posted April 17, 2022 Share Posted April 17, 2022 3 hours ago, Shen Wei said: Check if the api username and api password is correct. checked Quote Link to comment Share on other sites More sharing options...
Mahtab Hassan Posted April 17, 2022 Author Share Posted April 17, 2022 2 minutes ago, rukitinc said: checked Working or not? Quote Link to comment Share on other sites More sharing options...
rukitinc Posted April 17, 2022 Share Posted April 17, 2022 Just now, Shen Wei said: Working or not? no Quote Link to comment Share on other sites More sharing options...
Mahtab Hassan Posted April 17, 2022 Author Share Posted April 17, 2022 Just now, rukitinc said: no Pm me. LET ME CHECK Quote Link to comment Share on other sites More sharing options...
Ultimate Host Posted May 7, 2022 Share Posted May 7, 2022 When I use admin panel and trying to open link by button it redirects me to something like this app.domain.comadmin/[Something here.] I have set control panel domain like this: https://app.domain.com/. Quote Link to comment Share on other sites More sharing options...
TinkerMan Posted May 7, 2022 Share Posted May 7, 2022 Please please please do not use MOFHY unless you have fixed the 20+ secure issues. When you install MOFHY, you need to add a backslash "/" to the end of your client area URL. Quote Link to comment Share on other sites More sharing options...
Ultimate Host Posted May 7, 2022 Share Posted May 7, 2022 11 minutes ago, TinkerMan said: Please please please do not use MOFHY unless you have fixed the 20+ secure issues. When you install MOFHY, you need to add a backslash "/" to the end of your client area URL. Then what client panel would you reccomend? Quote Link to comment Share on other sites More sharing options...
TinkerMan Posted May 7, 2022 Share Posted May 7, 2022 I cannot recommend one, because there are no other ones besides MOFHY. MOFHY was awesome because it was the only option. Unfortunately, with number of severe vulnerabilities it has, it is unusable without a complete backend makeover. Quote Link to comment Share on other sites More sharing options...
