VistaPanel Customizations (VPT Project)
Anyx
On 11/18/2022 at 9:34 PM, Anyx said:
You notice however that @PlanetCloud didn't complete that verification. You aren't doing much to prove you're not a bot...
lol
On 11/19/2022 at 9:14 AM, PlanetCloud said:
Rest of the message:
I am not a bot, I am a {{THIS_WORLD.WIKI.INTTELIGENCE_CREATURE.sort('desc').pop().take(1)}}.
Thank You.
cat results
8 minutes ago, BastelPichi said:
VariableNotFound error in file captcha.php on line 13:
Ahh, compiler is returning wrong error. It's actually JS syntax, afaik PHP never have triple =
I am not using hcaptcha.
google.captcha.id is what i meant you buggy compiler
clear code for hcaptcha
use code for google recaptcha only.
Edited by AA22Dev
I love how this conversation went from showing off some cool VP customizations to proving that we are not bots.
1001001 100000 1101100 1101111 1110110 1100101 100000 1101000 1101111 1110111 100000 1110100 1101000 1101001 1110011 100000 1100011 1101111 1101110 1110110 1100101 1110010 1110011 1100001 1110100 1101001 1101111 1101110 100000 1110111 1100101 1101110 1110100 100000 1100110 1110010 1101111 1101101 100000 1110011 1101000 1101111 1110111 1101001 1101110 1100111 100000 1101111 1100110 1100110 100000 1110011 1101111 1101101 1100101 100000 1100011 1101111 1101111 1101100 100000 1010110 1010000 100000 1100011 1110101 1110011 1110100 1101111 1101101 1101001 1111010 1100001 1110100 1101001 1101111 1101110 1110011 100000 1110100 1101111 100000 1110000 1110010 1101111 1110110 1101001 1101110 1100111 100000 1110100 1101000 1100001 1110100 100000 1110111 1100101 100000 1100001 1110010 1100101 100000 1101110 1101111 1110100 100000 1100010 1101111 1110100 1110011 101110 1101 1010 1101 1010 1001001 100000 1100001 1101100 1110011 1101111 100000 1101100 1101111 1110110 1100101 100000 1101000 1101111 1110111 100000 1111001 1101111 1110101 100000 1100001 1100011 1110100 1110101 1100001 1101100 1101100 1111001 100000 1100100 1100101 1100011 1101111 1100100 1100101 1100100 100000 1110100 1101000 1101001 1110011 100000 111010 101001
I also love how you actually decoded this :)
REMINDER
In about 12 days, deprecated scripts will be removed. They will no longer be supported or hosted on our CDN, which means that any vPanel that depends on them will break.
You can either replace the link with a jsDelivr release one (that points to one of the releases that contain them), or, as we recommend, use the new scripts we've provided.
Perhaps we should do both?
  • 6 months later...
On 11/29/2022 at 2:18 AM, TinkerMan said:
Please confirm you are not a bot before making any statements.
OIP.cMV3Vq9z7CzML69FTqxxpgHaDq?pid=ImgDe
62626
Did I pass?
Since we haven't provided you with any updates recently, there has been a new update that concerns Element Changer.
Some of you may have noticed that a commit was pushed on the first of May. Well, @MeTooIDK reported an issue where Element Changer would break if the vPanel language was something other than English. This issue was fixed by @PlanetCloud, changing the script so that it no longer searches for elements based on their appearance name, but rather on their identifier.
We have updated the documentation to reflect the new changes, and provide a list with the identifiers you'll need to update your configuration with for the elements you're changing (modifying/removing). The adding elements functionality has been left untouched.
It goes without saying, but previous configuration will break. Please update as soon as possible.
Thank you @MeTooIDK and @PlanetCloud, and sorry it took me so long to update the docs and publish the release! 😂
