Mahtab Hassan Posted November 28, 2022 Share Posted November 28, 2022 2 hours ago, hello said: @Mahtab HassanHi, the smtp test for MOFH-R is working but the email templates aren't sending like when a user makes an account. have you edited email templates in MOFH-R Quote Link to comment Share on other sites More sharing options...
Anyx Posted November 28, 2022 Share Posted November 28, 2022 6 hours ago, BastelPichi said: Yes, you are. I reccomend to change your passwor every 10minutes if its that weak!!! You're assuming this isn't done already Quote Link to comment Share on other sites More sharing options...
hello Posted November 28, 2022 Author Share Posted November 28, 2022 7 hours ago, Mahtab Hassan said: have you edited email templates in MOFH-R @Mahtab HassanI havent edited them Quote Link to comment Share on other sites More sharing options...
hello Posted November 28, 2022 Author Share Posted November 28, 2022 Also, on your NXTS host, is that template made public? Quote Link to comment Share on other sites More sharing options...
hello Posted November 28, 2022 Author Share Posted November 28, 2022 Could you also please add TOS like xera has Quote Link to comment Share on other sites More sharing options...
hello Posted November 28, 2022 Author Share Posted November 28, 2022 (edited) Also, normal users still get the update thing in the dashboard, I thought only admins get it. A new version of this available. Click here to update. Edited November 28, 2022 by hello Quote Link to comment Share on other sites More sharing options...
hello Posted November 28, 2022 Author Share Posted November 28, 2022 Also, the update thing doesn't work, it doesn't actually update it. Some bugs, On the sidebar when you press dropdown then click something the dropdown bar goes up again. When you enter some information and enter something wrong it shows the error then deletes the stuff the user already typed. Happens on the login page and when people create a support ticket. Quote Link to comment Share on other sites More sharing options...
hello Posted November 28, 2022 Author Share Posted November 28, 2022 (edited) Also, how do I update manually cause auto doesnt work Also when you reset the password and enter the email it redirects to the login page and says logged in successfully Edited November 29, 2022 by hello Quote Link to comment Share on other sites More sharing options...
Mahtab Hassan Posted November 29, 2022 Share Posted November 29, 2022 8 hours ago, hello said: Could you also please add TOS like xera has ok Quote Link to comment Share on other sites More sharing options...
Mahtab Hassan Posted November 29, 2022 Share Posted November 29, 2022 8 hours ago, hello said: Also, on your NXTS host, is that template made public? no Quote Link to comment Share on other sites More sharing options...
Mahtab Hassan Posted November 29, 2022 Share Posted November 29, 2022 8 hours ago, hello said: Also, normal users still get the update thing in the dashboard, I thought only admins get it. A new version of this available. Click here to update. i see i will fix it Quote Link to comment Share on other sites More sharing options...
Mahtab Hassan Posted November 29, 2022 Share Posted November 29, 2022 8 hours ago, hello said: Also, the update thing doesn't work, it doesn't actually update it. Some bugs, On the sidebar when you press dropdown then click something the dropdown bar goes up again. When you enter some information and enter something wrong it shows the error then deletes the stuff the user already typed. Happens on the login page and when people create a support ticket. update the files from github Quote Link to comment Share on other sites More sharing options...
hello Posted November 29, 2022 Author Share Posted November 29, 2022 2 hours ago, Mahtab Hassan said: no Will you ever make it public, because the tabler css looks better than than the admin tle but the one you are using on nxts host looks like tabler but it has the side bar and looks so much better than both Quote Link to comment Share on other sites More sharing options...
hello Posted November 29, 2022 Author Share Posted November 29, 2022 1 hour ago, Mahtab Hassan said: update the files from github How do I do that? Because I remember if I replace everything it asks me to set up again then it will wipe out the database. Quote Link to comment Share on other sites More sharing options...
TinkerMan Posted November 29, 2022 Share Posted November 29, 2022 Only updated the files that have been changed... Quote Link to comment Share on other sites More sharing options...
hello Posted January 2, 2023 Author Share Posted January 2, 2023 On 11/29/2022 at 6:06 PM, Mahtab Hassan said: ok hello, how do I fix the email SMTP problem. When I press test it sends the tets email but when I reset password or something it doesn't send email Thanks Quote Link to comment Share on other sites More sharing options...
Mahtab Hassan Posted January 8, 2023 Share Posted January 8, 2023 On 1/2/2023 at 5:17 AM, hello said: hello, how do I fix the email SMTP problem. When I press test it sends the tets email but when I reset password or something it doesn't send email Thanks i don't know. Quote Link to comment Share on other sites More sharing options...
hello Posted January 24, 2023 Author Share Posted January 24, 2023 @Mahtab HassanOk thanks Quote Link to comment Share on other sites More sharing options...
Mahtab Hassan Posted January 26, 2023 Share Posted January 26, 2023 On 1/24/2023 at 1:04 PM, hello said: @Mahtab HassanOk thanks ok Quote Link to comment Share on other sites More sharing options...
hello Posted February 2, 2023 Author Share Posted February 2, 2023 @Mahtab HassanNo possible way to fix it? Quote Link to comment Share on other sites More sharing options...
Mahtab Hassan Posted February 2, 2023 Share Posted February 2, 2023 7 hours ago, hello said: @Mahtab HassanNo possible way to fix it? i don't think so Quote Link to comment Share on other sites More sharing options...
hello Posted February 7, 2023 Author Share Posted February 7, 2023 @Mahtab HassanMany other people have same problem Quote Link to comment Share on other sites More sharing options...
Mahtab Hassan Posted February 10, 2023 Share Posted February 10, 2023 On 2/7/2023 at 8:38 AM, hello said: @Mahtab HassanMany other people have same problem i just gave up Quote Link to comment Share on other sites More sharing options...
hello Posted February 11, 2023 Author Share Posted February 11, 2023 Both Quote Link to comment Share on other sites More sharing options...
