Xera Simple mailer not working
hello
Hello,
I know that this is about Xera and not much to do with MOFH but if you could help that would be great. When I use the simple mailer and enter the correct credentials for the SMTP and when I press test it keeps giving me An error occurred please try again. If anyone knows what the problem is please tell me.
Thank you so much.
  • Replies 119
  • Created
  • Last Reply
Top Posters In This Topic
10 hours ago, hello said:
@BastelPichiThanks, I am using mailgun. When I test these providers with a SMTP test website it works but with Xera it always gives me an error please try again.
That's strange, I assume you're using port 587 for the requests.
As it just so happens, Xera's support by the original developer is discontinued, as he's moved on to https://github.com/mahtab2003/MOFH-R. You may want to check that out and see if SMTP works for it.
20 hours ago, hello said:
What php version do I need?
Xera can be ran on PHP 7.2 up to 7.4.
MOFH-R can be ran on PHP 5.6 up to 7.4
Both do not support PHP 8.
Also how did you know about the new software coming out?
I am assuming the new software is MOFH-R. If it is:
@Mahtab Hassan said on October 23rd:
And then on the 29th he announced it:
Edited by Pansani
I'm not familiar with php version 8 and I'm just using PHP version 7.4 soon i will add support for PHP version 8 on MOFH-R
@Mahtab Hassan
<?php
defined('BASEPATH') OR exit('No direct script access allowed');
$config['protocol'] = 'smtp';
$config['mailtype'] = 'html';
$config['wordwrap'] = TRUE;
$config['wrapchars'] = 1000;
$config['smtp_timeout'] = 300;
$config['smtp_crypto'] = 'tls';
This is what I changed it to, is it correct?
@Mahtab Hassan
<?php
$config['smtp_crypto'] = tls;
I also tried this, they both didnt change the error
7 hours ago, hello said:
@Mahtab Hassan
<?php
this one is right
