Santiago Posted July 12, 2024 Share Posted July 12, 2024 Hello, I just set up my hosting back, now with a better name, and will be active without more name changes or migrations. Any suggestions? SSL certificates now have many providers: Let's Encrypt, ZeroSSL and GoGetSSL Website: https://waveshost.webcr.top Quote Link to comment Share on other sites More sharing options...
Mayank657 Posted July 12, 2024 Share Posted July 12, 2024 6 hours ago, Santiago said: Hello, I just set up my hosting back, now with a better name, and will be active without more name changes or migrations. Any suggestions? SSL certificates now have many providers: Let's Encrypt, ZeroSSL and GoGetSSL Website: https://waveshost.webcr.top Email verification system dont work, I didn't get any email. Github login doesn't work it just stuck at the callback screen with blank page Quote Link to comment Share on other sites More sharing options...
BastelPichi Posted July 12, 2024 Share Posted July 12, 2024 You might want to change the text on that page. Email sending does not seem to work. Quote Link to comment Share on other sites More sharing options...
TinkerMan Posted July 12, 2024 Share Posted July 12, 2024 Disk space is not unlimited, it’s 5GB You need a link back to iFN The about us page is a run-on sentence (And Softaculous should be capitalized) you might want to add a login button to the top menu on the flip side, it’s designed quite well for mobile, and the homepage looks good! Quote Link to comment Share on other sites More sharing options...
Santiago Posted July 12, 2024 Author Share Posted July 12, 2024 2 hours ago, BastelPichi said: You might want to change the text on that page. Email sending does not seem to work. It worked? Quote Link to comment Share on other sites More sharing options...
Santiago Posted July 12, 2024 Author Share Posted July 12, 2024 (edited) 3 hours ago, BastelPichi said: You might want to change the text on that page. Email sending does not seem to work. Now the email sending was fixed Edited July 12, 2024 by Santiago Quote Link to comment Share on other sites More sharing options...
Santiago Posted July 12, 2024 Author Share Posted July 12, 2024 4 hours ago, Mayank657 said: Email verification system dont work, I didn't get any email. Github login doesn't work it just stuck at the callback screen with blank page I don't why it won't worked, I just checked and works perfectly, but in my logs it was an user_name can't be null exception so I made user_name null allowed Quote Link to comment Share on other sites More sharing options...
Agent Death Posted July 13, 2024 Share Posted July 13, 2024 Damn this is quite good Quote Link to comment Share on other sites More sharing options...
Mayank657 Posted July 13, 2024 Share Posted July 13, 2024 11 hours ago, Santiago said: I don't why it won't worked, I just checked and works perfectly, but in my logs it was an user_name can't be null exception so I made user_name null allowed I think it cannot get user_name field from github. Thats why when i Signed using github my username was blank Quote Link to comment Share on other sites More sharing options...
Santiago Posted July 13, 2024 Author Share Posted July 13, 2024 49 minutes ago, Mayank657 said: I think it cannot get user_name field from github. Thats why when i Signed using github my username was blank Yes, maybe there's a weird thing with your username Quote Link to comment Share on other sites More sharing options...
Santiago Posted July 13, 2024 Author Share Posted July 13, 2024 3 hours ago, Agent Death said: Damn this is quite good Thanks Quote Link to comment Share on other sites More sharing options...
Mayank657 Posted July 13, 2024 Share Posted July 13, 2024 7 hours ago, Santiago said: Yes, maybe there's a weird thing with your username Or it can be with xera's code Quote Link to comment Share on other sites More sharing options...
Santiago Posted July 13, 2024 Author Share Posted July 13, 2024 I thought that but I checked and there's no problem Quote Link to comment Share on other sites More sharing options...
BastelPichi Posted July 14, 2024 Share Posted July 14, 2024 Some reccomendations: Get shorter domains for clients/your homepage Add a note to let the user know that the password field can be left empty. Most user will prefer the randomly generated one. its kind of weird that only the cPanel start page has dark mode make the username in the account list clickable You probably dont want to offer Lets Encrypt for subdomains. At some point youll reach their rate limits, and cPanel wont get SSL anymore. add a copy button in the SSL setup, that will only copy "_acme-challenge". (or make it so that you can copy this seperatly from the rest of the domain, its easier and faster this way) Requesting the cert (after you have verified) failed for me for the first two times, you might want to look into that @Santiago you interested in joining the iFastNet Discord Server? Would probably be easier to communicate that way, especially when youre working a lot on Xera now... Quote Link to comment Share on other sites More sharing options...
Santiago Posted July 14, 2024 Author Share Posted July 14, 2024 Yeah, sure I will join to Discord, from tomorrow I will be slower developing and less active because my vacation time ends but I will try to remain active, currently I'm working on the Xera CI4 migration Quote Link to comment Share on other sites More sharing options...
Fastniteowl Posted July 19, 2024 Share Posted July 19, 2024 On 7/13/2024 at 6:13 AM, Agent Death said: Damn this is quite good Agreed, the client and registration page is very good and seems secure. the design is very good as well, looks very clean and good. However the domain should match that, in the future you might need a better and easier domain for your company =) Quote Link to comment Share on other sites More sharing options...
Santiago Posted July 29, 2024 Author Share Posted July 29, 2024 (edited) On 7/12/2024 at 11:07 AM, TinkerMan said: Disk space is not unlimited, it’s 5GB You need a link back to iFN The about us page is a run-on sentence (And Softaculous should be capitalized) you might want to add a login button to the top menu on the flip side, it’s designed quite well for mobile, and the homepage looks good! Hello, I was focused on my studies and working on Xera too, so I didn't do it before, I fixed Softaculous, and disk space, about link to iFN it is on plans, the login buttom I wil add after because I dont much time due my college (I need to update my code and all of my language files to add that buttom). Thanks for your feedback, congrats for TinkerHost. Edited July 29, 2024 by Santiago Quote Link to comment Share on other sites More sharing options...
luluhoste Posted August 29, 2024 Share Posted August 29, 2024 On 7/12/2024 at 9:50 AM, Santiago said: Hello, I just set up my hosting back, now with a better name, and will be active without more name changes or migrations. Any suggestions? SSL certificates now have many providers: Let's Encrypt, ZeroSSL and GoGetSSL Website: https://waveshost.webcr.top Cela semble un bon projet 🙂... --- trad google--- This seems like a good project🙂... Quote Link to comment Share on other sites More sharing options...
Santiago Posted August 29, 2024 Author Share Posted August 29, 2024 7 hours ago, luluhoste said: Cela semble un bon projet 🙂... --- trad google--- This seems like a good project🙂... Thanks Quote Link to comment Share on other sites More sharing options...
Ahmed Bek AtiA Posted September 11, 2024 Share Posted September 11, 2024 I need your tempelet Quote Link to comment Share on other sites More sharing options...
foxywox Posted October 31, 2024 Share Posted October 31, 2024 I tried to use this but my account was randomly deleted Quote Link to comment Share on other sites More sharing options...
