Mayank657 Posted December 4, 2022 Share Posted December 4, 2022 Can Anybody Help Me Add SSL Generator in MOFH Reseller Quote Link to comment Share on other sites More sharing options...
TinkerMan Posted December 4, 2022 Share Posted December 4, 2022 @BastelPichi, I am getting a 404 on that last GH link you shared. Quote Link to comment Share on other sites More sharing options...
Mayank657 Posted December 4, 2022 Author Share Posted December 4, 2022 7 hours ago, BastelPichi said: Using the GoGetSSL API is rather easy. They have good docs and you can find details on their github: https://github.com/gogetssl/api/wiki. You can also take a look at the integrations in these projects: https://github.com/mahtab2003/MOFH-R https://github.com/mahtab2003/Xera Let's Encrypt is way more compliated and might not work on Free Hosting. For my tool, I used https://github.com/afosto/yaac. You also need access to cloudflare api or similar (= wont work with freenom) Bro Can we do zerossl and Google public ca Quote Link to comment Share on other sites More sharing options...
TinkerMan Posted December 4, 2022 Share Posted December 4, 2022 2 hours ago, Mayank657 said: zerossl You can, but I don't think it is free. Just use their API: https://zerossl.com/documentation/api/ 2 hours ago, Mayank657 said: Google public ca Don't know if that will work with free hosting, but read this: https://cloud.google.com/certificate-manager/docs/public-ca-tutorial Quote Link to comment Share on other sites More sharing options...
SpookyKipper Posted December 5, 2022 Share Posted December 5, 2022 14 hours ago, TinkerMan said: You can, but I don't think it is free ZeroSSL Custom API is paid, but the ZeroSSL ACME Server is free Quote Link to comment Share on other sites More sharing options...
SpookyKipper Posted December 5, 2022 Share Posted December 5, 2022 17 hours ago, Mayank657 said: Bro Can we do zerossl and Google public ca You can, but it's basically the same setup as Let's Encrypr, GoGetSSL seems to be easier Quote Link to comment Share on other sites More sharing options...
Mayank657 Posted June 5, 2023 Author Share Posted June 5, 2023 Can Anybody help me make ssl generator. Quote Link to comment Share on other sites More sharing options...
TinkerMan Posted June 5, 2023 Share Posted June 5, 2023 What do you mean? Quote Link to comment Share on other sites More sharing options...
Mayank657 Posted June 6, 2023 Author Share Posted June 6, 2023 9 hours ago, TinkerMan said: What do you mean? I mean that can anybody help me make ssl generator for hosting Ssl generator like infinityfree have Quote Link to comment Share on other sites More sharing options...
Mayank657 Posted June 6, 2023 Author Share Posted June 6, 2023 On 12/5/2022 at 4:55 PM, SpookyKipper said: You can, but it's basically the same setup as Let's Encrypr, GoGetSSL seems to be easier Can Please give the steps Quote Link to comment Share on other sites More sharing options...
TinkerMan Posted June 6, 2023 Share Posted June 6, 2023 You can grab the files from Xera and make them work with your own system, you can read the API docs of the SSL provider you want to use to create your own, or you could offer a monitory insentive to people on the forum to see if someone will do it for you. Quote Link to comment Share on other sites More sharing options...
TinkerMan Posted June 6, 2023 Share Posted June 6, 2023 Also, why did you open a duplicate topic? Can @Dimitris or @Chronos merge these? https://www.byet.net/index.php?/topic/63488-can-anybody-help-me-add-ssl-generator-in-mofh-reseller/#comment-101466 Quote Link to comment Share on other sites More sharing options...
Mayank657 Posted June 7, 2023 Author Share Posted June 7, 2023 14 hours ago, TinkerMan said: or you could offer a monitory insentive to people on the forum to see if someone will do it for you. How can I do this Quote Link to comment Share on other sites More sharing options...
Mayank657 Posted June 7, 2023 Author Share Posted June 7, 2023 (edited) 14 hours ago, TinkerMan said: You can grab the files from Xera and make them work with your own system Bro GenerateArea also have a ssl generator or not Edited June 7, 2023 by Mayank657 Quote Link to comment Share on other sites More sharing options...
SpookyKipper Posted June 7, 2023 Share Posted June 7, 2023 6 hours ago, Mayank657 said: How can I do this Basically you pay people to do it for you 5 hours ago, Mayank657 said: Bro GenerateArea also have a ssl generator or not Yes, but it's broken. It's a fork of Xera anyways, so referring to Xera's one would be enough. Quote Link to comment Share on other sites More sharing options...
Mayank657 Posted June 12, 2023 Author Share Posted June 12, 2023 On 6/6/2023 at 7:04 PM, TinkerMan said: You can grab the files from Xera and make them work with your own system. Bro which files Quote Link to comment Share on other sites More sharing options...
TinkerMan Posted June 12, 2023 Share Posted June 12, 2023 The files that are relevant to SSL installation. Quote Link to comment Share on other sites More sharing options...
Mayank657 Posted June 13, 2023 Author Share Posted June 13, 2023 21 hours ago, TinkerMan said: The files that are relevant to SSL installation. Where are the files in which directory Quote Link to comment Share on other sites More sharing options...
TinkerMan Posted June 13, 2023 Share Posted June 13, 2023 I mean that’s kind of for you to find. You won’t be able to just copy the code either, your going to have to change it to work with your platform (No, we are not going to give you step by step help for free here). You’ll find the files in the functions folder (Honestly, that may be the wrong name. Just look around, it can’t be that hard to find), with names that include the letters “SSL” Quote Link to comment Share on other sites More sharing options...
Santiago Posted July 12, 2024 Share Posted July 12, 2024 Xera now supports Let's Encrypt and ZeroSSL, Google Trust is enabled but don't work because Google restrictions and one account limitation with EAB, so it will be fixed later, for now a new release is coming Quote Link to comment Share on other sites More sharing options...
qwe Posted August 2, 2024 Share Posted August 2, 2024 (edited) On 7/12/2024 at 3:31 AM, Santiago said: Xera now supports Let's Encrypt and ZeroSSL Hi, Thanks for working on Xera. I have checked your website, and get SSL from these provider, but I don't know how to install these SSL. DO I need to wait since it's pending and processing? Thanks . Edited August 2, 2024 by qwe Quote Link to comment Share on other sites More sharing options...
TinkerMan Posted August 2, 2024 Share Posted August 2, 2024 You need to add the CNAME record shown at the bottom of your screenshot. Quote Link to comment Share on other sites More sharing options...
qwe Posted August 3, 2024 Share Posted August 3, 2024 (edited) 5 hours ago, TinkerMan said: You need to add the CNAME record shown at the bottom of your screenshot. Thanks. Edited August 3, 2024 by qwe Quote Link to comment Share on other sites More sharing options...
qwe Posted August 3, 2024 Share Posted August 3, 2024 I have another question: I got a question related to use Cloudflare Turnstile SSL. My understanding is that the domain.com will have to point to the ifastnet server or registration to get a new name won't work. However, on the other hand, if the domain.com doesn't use any cloudflare service, it won't be able to set up the Turnstile. So my questions is how to set up the Turnstile, if domain.com uses ifastnet nameserver, and to get the Turnstile service? Quote Link to comment Share on other sites More sharing options...
SpookyKipper Posted August 3, 2024 Share Posted August 3, 2024 29 minutes ago, qwe said: I have another question: I got a question related to use Cloudflare Turnstile SSL. My understanding is that the domain.com will have to point to the ifastnet server or registration to get a new name won't work. However, on the other hand, if the domain.com doesn't use any cloudflare service, it won't be able to set up the Turnstile. So my questions is how to set up the Turnstile, if domain.com uses ifastnet nameserver, and to get the Turnstile service? Cloudflare Turnstile is an anti-bot service and not SSL certificate Quote Link to comment Share on other sites More sharing options...
