freehost44u Posted November 23, 2021 Share Posted November 23, 2021 (edited) @Shen Wei I installed, santydesignscr's multi version. and received verification code from email, however, after filling in the code, it won't take me anywhere. I am not able to create account, and I also notice that there is no email address showing up, the red crossed email address. I installed mahtab2003's version. put all the files from src folder into the root folder. the email address will show up like the santyhost.ga(the screenshot below), yet I face the same issue as I mentioned above, after filling in the verification code, nothing happens afterwards. I won't be able to create account neither. By the way, at one time, I see somewhere told me to update the IP at the reseller account. However, after reinstalled many times, it doesn't show up any more. How do I find the right IP address to fill in the following place: API Allowed IP Address (main IP of server you are connecting from) Edited November 24, 2021 by freehost44u Quote Link to comment Share on other sites More sharing options...
freehost44u Posted November 23, 2021 Share Posted November 23, 2021 1 hour ago, BastelPichi2 said: The plan can be anything, I usually just call it "Free Hosting". Thanks for your reply. Very helpful. Quote Link to comment Share on other sites More sharing options...
Mahtab Hassan Posted November 24, 2021 Author Share Posted November 24, 2021 6 hours ago, freehost44u said: @Shen Wei I installed, santydesignscr's multi version. and received verification code from email, however, after filling in the code, it won't take me anywhere. I am not able to create account, and I also notice that there is no email address showing up, the red crossed email address. I installed mahtab2003's version. put all the files from src folder into the root folder. the email address will show up like the santyhost.ga(the screenshot below), yet I face the same issue as I mentioned above, after filling in the verification code, nothing happens afterwards. I won't be able to create account neither. By the way, at one time, I see somewhere told me to update the IP at the reseller account. However, after reinstalled many times, it doesn't show up any more. How do I find the right IP address to fill in the following place: API Allowed IP Address (main IP of server you are connecting from) You can find your server ip in your cpanel account not vPanel account. Let me see the build if I can find something for you Quote Link to comment Share on other sites More sharing options...
Gautam Posted November 24, 2021 Share Posted November 24, 2021 12 hours ago, TinkerMan said: @Gautam, try refreshing that file by copying its contents from GitHub. i have fixed the error thank you. my email service is not working in PROJECT-HUSTAL Quote Link to comment Share on other sites More sharing options...
Gautam Posted November 24, 2021 Share Posted November 24, 2021 20 hours ago, Shen Wei said: The passwd filed is missing from form element thanks i solved this issue. In PROJECT-HUSTAL can we send mails? Quote Link to comment Share on other sites More sharing options...
Pro Hostinga Posted November 24, 2021 Share Posted November 24, 2021 3 hours ago, Gautam said: In PROJECT-HUSTAL can we send mails? Yes you can send emails in hustal. Quote Link to comment Share on other sites More sharing options...
Santiago Posted November 24, 2021 Share Posted November 24, 2021 Ohhh sorry for not helping @freehost44u, that said that the community could help you solve the problem, I am not always active Quote Link to comment Share on other sites More sharing options...
Mahtab Hassan Posted November 24, 2021 Author Share Posted November 24, 2021 5 hours ago, Gautam said: thanks i solved this issue. In PROJECT-HUSTAL can we send mails? Yes Quote Link to comment Share on other sites More sharing options...
MeTooIDK Posted November 24, 2021 Share Posted November 24, 2021 On 11/23/2021 at 5:56 AM, freehost44u said: Yes. Thanks very much for your help. The port need to be 587, and not 465, regardless of using SMTP service provider, right? I see another discussion about this on Github. Would you and @Santiago please help me this? I have issue with register an account. On the following screeshot. After registration, it says, "Something went's wrong!". I did not receive any email, however, I can see the subdomain registered in my VP reseller. I added the following code in handler/index.php page, to get the error code. ini_set('display_errors', 1); ini_set('display_startup_errors', 1); error_reporting(E_ALL); It is right? By the way, Does the plan need to be one word, say, "free" instead "best_plan"? What does the green box of 2 servers mean? It's not clickable though. Sorry for asking you two so many questions. Thank BastelPichi2 and TinkerMan for your suggestion. I have this problem too, easiest way is replace function files to Lastest MoFHY Release Quote Link to comment Share on other sites More sharing options...
Gautam Posted November 24, 2021 Share Posted November 24, 2021 which free email service can i use. pls suggest some services Quote Link to comment Share on other sites More sharing options...
Mahtab Hassan Posted November 24, 2021 Author Share Posted November 24, 2021 2 minutes ago, Gautam said: which free email service can i use. pls suggest some services You can use yandex and Gmail smtp Quote Link to comment Share on other sites More sharing options...
Gautam Posted November 24, 2021 Share Posted November 24, 2021 when will PROJECT-HUSTAL get updates Quote Link to comment Share on other sites More sharing options...
Mahtab Hassan Posted November 24, 2021 Author Share Posted November 24, 2021 Just now, Gautam said: when will PROJECT-HUSTAL get updates Never Quote Link to comment Share on other sites More sharing options...
Gautam Posted November 24, 2021 Share Posted November 24, 2021 ok is it discontinued? Quote Link to comment Share on other sites More sharing options...
TinkerMan Posted November 24, 2021 Share Posted November 24, 2021 I think so. MOFHY-Lite is a better alternative anyway. Quote Link to comment Share on other sites More sharing options...
Ultimate Host Posted November 24, 2021 Share Posted November 24, 2021 Hello, with what service does ssl api works? Quote Link to comment Share on other sites More sharing options...
TinkerMan Posted November 24, 2021 Share Posted November 24, 2021 GoGetSSL Quote Link to comment Share on other sites More sharing options...
Mahtab Hassan Posted November 24, 2021 Author Share Posted November 24, 2021 2 hours ago, Gautam said: ok is it discontinued? Yes Quote Link to comment Share on other sites More sharing options...
Ultimate Host Posted November 24, 2021 Share Posted November 24, 2021 51 minutes ago, TinkerMan said: GoGetSSL Thanks Quote Link to comment Share on other sites More sharing options...
Gautam Posted November 29, 2021 Share Posted November 29, 2021 my gmail smtp not working ? i have also turned on less secure apps Quote Link to comment Share on other sites More sharing options...
Ultimate Host Posted November 29, 2021 Share Posted November 29, 2021 5 hours ago, Gautam said: my gmail smtp not working ? i have also turned on less secure apps I have used outlook and everything worked pretty fine. Try using outlook. Quote Link to comment Share on other sites More sharing options...
Parimu Hosting for Student Posted December 5, 2021 Share Posted December 5, 2021 (edited) I have problem. I has been created my site used for client area login. Located in:https://admin.studenthosting.ga But, I have problem with client account creation. I tested on test user, and this user can't got email and account not showing on clientarea. And account has created in reseller panel, but I couldn't find password. But, verification mail on first registration is show. Seems, this error I found on this forum, but I forgoten place or links. Edited December 5, 2021 by Parimu Hosting for Student Added sentence: And account has created in reseller panel, but I couldn't find password. Quote Link to comment Share on other sites More sharing options...
Parimu Hosting for Student Posted December 5, 2021 Share Posted December 5, 2021 33 minutes ago, BastelPichi2 said: For me the signup works fine. I just created an account, got the email, verified my account and done. I know, create account is working. But, create hosting account have problem "something went wrong" Quote Link to comment Share on other sites More sharing options...
TinkerMan Posted December 5, 2021 Share Posted December 5, 2021 That error sounds like your MOFH API keys are setup correctly. Quote Link to comment Share on other sites More sharing options...
Mahtab Hassan Posted December 6, 2021 Author Share Posted December 6, 2021 14 hours ago, TinkerMan said: That error sounds like your MOFH API keys are setup correctly. This bug EXISTS in mofhy multi lang because it has not been updated to latest mofhy lite Quote Link to comment Share on other sites More sharing options...
